Author Topic: Fitting Polar FIS +  (Read 15963 times)
Offline bacillus
  • -Receive: 451
Re: Fitting Polar FIS +
« Reply #15 on: February 13, 2014, 10:58:11 pm »
In addition to the question of if you have a highline mfd, is your polar box plastic or aluminium? If aluminium is it silver or black?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #16 on: February 13, 2014, 11:00:30 pm »
Yeah have the high line display, do i need anything else...?  :happy2:
Didn't fancy having to take it out again  :sad1: :sad1: :sad1:
Left it in a place i could access the box, just encase it could be updated, when connected !  :ashamed:
Silver is the way !
Offline bacillus
  • -Receive: 451
« Reply #17 on: February 13, 2014, 11:08:29 pm »
If connected then you need to update using the polar update in the configuration setting on the mfd screen.
If you can manage to disconnect the plug from the box then that puts it in update mode and can then be updated by just connecting your usb cable after getting on to the polar update site.
NB The site only works with Internet explorer
« Last Edit: February 13, 2014, 11:10:06 pm by bacillus »
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #18 on: February 13, 2014, 11:09:29 pm »
aluminium it is silver matey... uploading pictures now ......
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #19 on: February 13, 2014, 11:10:14 pm »
 :popcornsoda:
Silver is the way !
« Reply #20 on: February 13, 2014, 11:12:54 pm »
i know when i have had a flat battery on my car mine doesn't work -so i disconnected the battery again leave it a fewminutes and it comes back on
Offline bacillus
  • -Receive: 451
« Reply #21 on: February 13, 2014, 11:15:14 pm »
Ok, if you get to the update site for the update you want to upgrade to FIS_Adv_v0.4.2RZ1(Red_dot)(EN_ES_FR_IT_PT). The updater will also show you if you have a PF03 (advanced) or not by the updates it offers you.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #22 on: February 13, 2014, 11:16:43 pm »
 :drinking: Cheers matey!
"update in the configuration setting on the mfd screen" I would need to be able to access this first on my dash, would that be right...?  :innocent:
If so then it needs removed  :fighting2:
It's not doing any harm like this?
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #23 on: February 13, 2014, 11:18:22 pm »
I could maybe try that now, say disconnect it for 10 mins?
.... just don't fancy pulling the polar out tonight...
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #24 on: February 13, 2014, 11:20:40 pm »
 :happy2: Cheers B:
http://www.auto-polar.com/index-load-Polar_Fis.htm
But i still need to take it out of the car to do this  :signLOL:
Silver is the way !
Offline bacillus
  • -Receive: 451
« Reply #25 on: February 13, 2014, 11:21:47 pm »
The box supports updating both in and out of the car.
If you call it a night and leave the polar disconnected from the car then it's possible that your battery may go flat tomorrow as the head unit may not fully turn off.
Quote
Correct.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #26 on: February 13, 2014, 11:34:39 pm »
Quote
Correct.
I will battle on  :fighting:  With your guy's support, we will get something sorted... :signLOL: Battery disconnected for now, until i find a lead!
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #27 on: February 13, 2014, 11:46:36 pm »
Battery being disconnected did not seem to work  :sad1:
So it needs removed to do the update, as i will not see it on the high line screen?
Silver is the way !
Offline bacillus
  • -Receive: 451
« Reply #28 on: February 14, 2014, 10:23:42 am »
Good luck with the update.
My gut feeling is that there is an issue with the polar cable itself as it's easy to break a wire at either end and not notice it without a close inspection.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #29 on: February 14, 2014, 10:49:45 am »
Cheer matey !
I have the box out, so when I go to the update page, it waits till I connect the lead to the polar, then goes to update/connect and shows up with problem!  :sad1:
Silver is the way !
