Author Topic: rns510 and arm rest mdi...poor sound quality when using mdi  (Read 1446 times)
Offline Leigh200sx
« on: February 28, 2014, 12:24:03 pm »
Hi I've tried searching and found a few answers but just to clarify Il ask here to... Right last weekend I fitted a rns510,brilliant and much better than my mfd2 which is now in her gt tdi. Yesterday I fitted a arm rest mdi and it's again brilliant, every thing works and all displays on my highline but the sound quality from mdi is piss poor... I've tried cd and sd card and there fine so to is hdd and radio...any help on to finding  a solution please
Offline Luka
Re: rns510 and arm rest mdi...poor sound quality when using mdi
« Reply #1 on: February 28, 2014, 01:01:58 pm »
Have a look here mate:
http://www.my-gti.com/688/volkswagen-media-device-interface-mdi-retrofit
In particular, the installation instructions and pin locations.
Sold - 2006 Tornado Red GTI 3dr
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: March 02, 2014, 07:47:14 pm »
check the settings on the rns
you want to change aux to low
Cluster and Key coding
Location Great Yarmouth
Offline Leigh200sx
« Reply #3 on: March 04, 2014, 09:37:34 pm »
Done this and it's still terrible..
Offline SI-R32
  • -Receive: 126
« Reply #4 on: March 04, 2014, 09:47:48 pm »
are you sure the 3 wires that go into the 510 are the correct way round, when i did mine a very long time ago i found i got them wrong and had to have a little swap around, all way a lot better after, might be worth a try.
Offline GLIDN
« Reply #5 on: March 06, 2014, 09:40:34 pm »
going from RCD300/500 t RCD310/510/RNS510.
Requires two of the wires to be swapped around while the 3rd wire needs to be relocated to a new pin.
