Author Topic: How do/can you remove rear discs without removing carriers  (Read 10604 times)
Offline Airz182
« on: March 15, 2014, 09:32:00 pm »
Planning of getting new disc and pads for the rear next week, and painting them before installation.
Had the wheel off today to get the dust shield off from the rear caliper.
Managed to get the caliper off, but couldn't get the disc off past the carrier.
Is there a special tool to get the carrier off?? Or a certain way to shimmy the disc past the carrier?
If this is the case Tho i don't really want to scratch my
New disc when fitting them. Any help would be appreciated thanks
Instagram- airz182
Offline doylebros
  • -Receive: 310
Re: How do/can you remove rear discs without removing carriers
« Reply #1 on: March 15, 2014, 09:37:03 pm »
Tool - 12spline or 3 square but can't remember if it's M12 or M14
This is it
http://www.vwgenuineparts.co.uk/vw_golf_rear_pads_and_discs_replacement.shtml
« Last Edit: March 15, 2014, 09:38:34 pm by doylebros »
Offline Airz182
« Reply #2 on: March 15, 2014, 09:42:59 pm »
Thanks very much luckily i bought a multispline set! Which im yet to use!
Instagram- airz182
Offline doylebros
  • -Receive: 310
« Reply #3 on: March 15, 2014, 09:45:59 pm »
Mind there tight so you'll need a breaker bar and height - ramps the job!
Online Andy
« Reply #4 on: March 15, 2014, 09:49:59 pm »
i did some back plates at work  on a gttdi and i had to remove the carrier and wheel bearing but youcan cut a piece of that slides behind the carrier--The tools are m14 and m18 sockets
Offline Airz182
« Reply #5 on: March 15, 2014, 09:54:08 pm »
Ramps or maybe a job for someone else!!
The disc and pads dont look to old tbh. Only changing them because there rust!!
Instagram- airz182
Offline Airz182
« Reply #6 on: March 15, 2014, 09:55:41 pm »
I end up cutting a line in my back plate and smashung it off with a hammer because i couldn't get carrier off!
Instagram- airz182
Offline SI-R32
  • -Receive: 126
« Reply #7 on: March 15, 2014, 09:58:25 pm »
you should try undoing the multi splined bits with an extra drive shaft in the way, i've never sworn so much in my life
Online Andy
« Reply #8 on: March 15, 2014, 10:04:08 pm »
i used a long piece  of pipe :signLOL:
Offline JC88
« Reply #9 on: March 18, 2014, 06:21:49 pm »
Tried doing this the other weekend and the carrier bolts are a nightmare to get access to if you're only doing the job on your driveway. If you can manage to loosen them up with the shocks/springs etc in the way they it's obviously a straight forward job but like Si-R32 I was losing the will to live! Just changed the pads and got the discs changed by someone with a lot more patience than me (albeit with the benefit of a lift) :P
Offline Airz182
« Reply #10 on: March 18, 2014, 07:23:02 pm »
Im going to reattempt it at weekend now i now what tools to use, i am doing it on the driveway!!
The rear disc dont seem that old so maybe wernt changed that long ago!!  So the bolts may not be so tight!!
Luckly everything else ive undone so far has been copper greased!  So fingers crossed!!
Instagram- airz182
Offline JC88
« Reply #11 on: March 18, 2014, 09:45:09 pm »
Dont know if it's any use to you mate, but theres a video (link below) which is handy in case you need to double check anything or whatnot. Sure you've got it all under control since you've done the pads and whatnot...
Offline karl210
« Reply #12 on: March 20, 2014, 10:58:03 am »
You will have a fighting chance if you can get your car on a set of decent high drive on ramps or some really tall axle stands, if not dont bother and pay someone £10 or whatever at a garage to crack them off for you.
Offline andybon
« Reply #13 on: March 23, 2014, 01:21:16 pm »
I managed to get the disk off without taking the carrier off, takes a little bit of jiggling but can be done!
How hard can it be?
Offline doylebros
  • -Receive: 310
« Reply #14 on: March 23, 2014, 02:03:16 pm »
Did you try getting the new disc back on yet?
