Author Topic: Camber wear  (Read 1775 times)
Offline luketurner
Camber wear
« on: March 30, 2014, 11:48:32 am »
Hi guys,
Just a quick one with my mot coming up, my rear tyres have camber wear, So I flipped them so the wear is on the edge of the outside, the tread across the middle of the tyre is still legal, just wondering if these will pass an mot?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=do5mfum9lm7cs0pjr0ja7b16nq&/topic,19740.0.html
Re: Camber wear
« Reply #1 on: March 30, 2014, 11:49:10 am »
If they are above the wear markers then yes they should pass
Offline luketurner
Re: Camber wear
« Reply #2 on: March 30, 2014, 11:53:21 am »
Even if one edge is pretty much completely bald? Thanks for the quick reply man, just wanted to double check!
Re: Camber wear
« Reply #3 on: March 30, 2014, 11:57:47 am »
If one edge is bald then they will fail... or at least the should fail
Offline luketurner
Re: Camber wear
« Reply #4 on: March 30, 2014, 04:47:17 pm »
Thanks mate, looks like ill be changing them :)
Offline Chris92
  • -Given: 33
Re: Camber wear
« Reply #5 on: March 30, 2014, 05:37:03 pm »
Yes a fail and another thing to remember is if your swapping tyres around make sure they ain't directional tyres because swapping tyres to the other side will mean the tyre isn't rotating the way it should (if directional) and that will fail a mot to.
Offline luketurner
Re: Camber wear
« Reply #6 on: March 30, 2014, 06:19:49 pm »
they are directional tyres, but it was only the 2 rears that needed flipping, just swapped the sides of the car they were on, so they are still spinning the right way :)
Offline xjay1337
  • -Receive: 377
Re: Camber wear
« Reply #7 on: March 30, 2014, 06:54:03 pm »
Why...? The camber would make the same (worn) part of the tyre is in contact with the road.
Offline vRSAlex
  • -Receive: 253
Re: Camber wear
« Reply #8 on: March 30, 2014, 07:26:34 pm »
Still fine to pass the mot if very low on the edge.  As long as they is 3/4 thread then they should pass.
Follow AKS tuning on Facebook
Offline luketurner
Re: Camber wear
« Reply #9 on: March 30, 2014, 07:52:54 pm »
the camber wear is on the outside of the tyre :)
Thanks man, i think I'm just gonna go to the garage and ask if they'll pass as they are, as the inside tread is fine, just the camber wear. If not ill just change the wheels before my MOT
Offline BarberVW
Re: Camber wear
« Reply #10 on: March 30, 2014, 08:00:06 pm »
My thoughts also  :laugh:
Black 3 Door Manual | Bi-xenons | Winter pack | Luxury pack2 | Cruise control | Highline display | MFSW | 18" Monza 2's | Armrest | Glovebox MDI | Blue tint glass
Offline xjay1337
  • -Receive: 377
Re: Camber wear
« Reply #11 on: March 30, 2014, 08:02:23 pm »
You have positive camber? If it's on the outside of the tyre it's not camber wear.
Offline luketurner
Re: Camber wear
« Reply #12 on: March 30, 2014, 08:17:32 pm »
Its on the outside now i mean :)
Offline xjay1337
  • -Receive: 377
Re: Camber wear
« Reply #13 on: March 30, 2014, 08:33:01 pm »
Ohhh, I get you.
That works as long, as mentioned, the tyre is not designed to only be ran in one direction.  :smiley:
