Author Topic: Edition30 GTI Missfire :(  (Read 9275 times)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Edition30 GTI Missfire :(
« Reply #30 on: April 08, 2014, 12:39:08 pm »
And there is this stuff http://injectedstore.com/products/injected-engineering-direct-injection-de-carbon-foam
Although its more expensive.
I'll try the Wynns one, any volunteers for this?  :smiley:
Offline martziniuk
« Reply #31 on: April 08, 2014, 08:51:16 pm »
White spirit through the inlet temp sensor hole works a treat!
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline gingerguild
« Reply #32 on: April 09, 2014, 11:51:35 am »
I appear to be having exactly the same issue as the OP.  This thread has helped lots.  Given me a few things to try :)
I took my car to MidlandVW who plugged it in with no misfire reported but it is certainly something you can feel at idle after the car has warmed up a bit, I'm pretty sure I'm not imagining it  :scared:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #33 on: April 09, 2014, 02:26:31 pm »
It won't have logged a misfire fault code unless it's very serious. On VCDS you can use the misfire counter tool which logs soft misfires at idle you need a lot in a short period of time to throw up a fault code
Offline edpower
« Reply #34 on: April 24, 2014, 06:51:37 pm »
Saintsteve
« Reply #35 on: April 24, 2014, 07:23:23 pm »
Did you look at your live missfire count 1st??
Offline edpower
« Reply #36 on: April 25, 2014, 07:07:41 pm »
I have them on my polar fis, yes
