Author Topic: FAUL CODES 00768 AND 00771  (Read 19498 times)
Offline vr6 g3
« on: April 08, 2014, 08:58:49 pm »
Has anyone got any ideas, my Edition 30 has started to miss fire tonight under load and I'm getting these fault codes up.
It seems to be exactly like a coil pack down however I would of thought my diagnostics would of picked up a cylinder miss fire.
Only other thing I'm thinking is some kind of fuel pressure sensor??
I've cleared the codes and these 2 keep coming up together.
Fault codes are:
1,
00768 rear heater core temp sensor (g154)
Sporadic 001-upper limit exceeded
2,
00771 fuel level sensor (g)
Sporadic 001-upper level exceeded
Offline doylebros
Re: FAUL CODES 00768 AND 00771
« Reply #1 on: April 08, 2014, 09:39:07 pm »
 This site gives more info on your fault codes just put the code in the search:-
http://wiki.ross-tech.com/wiki/index.php/16684/P0300/000768
But your better getting a scan with VCDS
Here's a list of people local to you
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Offline vr6 g3
« Reply #2 on: April 08, 2014, 10:40:55 pm »
Thanks mate, with that link showing 000768 and mentioning a possible miss fire/coil pack I think I might start there before doing anything else as that confirms my first thoughts.
Other than that I'll take it somewhere for a proper diagnosis if its not that.
Offline doylebros
« Reply #3 on: April 08, 2014, 10:43:47 pm »
That's the other fault code explained
http://wiki.ross-tech.com/wiki/index.php/00771
If it helps!
Offline vr6 g3
« Reply #4 on: April 09, 2014, 08:03:40 pm »
Cheers mate, sorted it, my codes on the reader gave me a right bum steer !
I bought a couple of sensors first and no luck, then moved onto a coil pack and swapped them one at a time and sod's law the last one was faulty and all sorted now.
Thanks for your help, the codes you supplied did help.
