Author Topic: Warranty Repairs - Turbo, Coolant Leak, Engine Wiring Harness (not covered-£350)  (Read 7972 times)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
VERY good point. I'll back away now  :ashamed:
Offline MikLSP
Haha, no worries I appreciate the input. I went through the same thought process myself and I think I will still point it out to them that there was a wiring harness replaced just over two years ago and let them convince me that they're replacing a different one now  :wink:
« Last Edit: April 28, 2014, 08:52:56 pm by MikLSP »
Offline MJ
The two looms are completely different I'm afraid.
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline MikLSP
Thought as much when I saw a picture of the injector loom and it certainly didn't look like a 5 hour job.
Offline MJ
An hour if you're dragging your feet to be honest. The map sensor loom is a pig though.
Offline MikLSP
By the way, does the loom just go to the ECU or will they need to take the dash out too?
Offline MJ
Just to the ecu in the plenum chamber, dash removal is not required.
Offline MikLSP
Thanks, I'm glad they don't need to risk causing any damage to the interior  :wink:
