Hi All,
Just bagged myself some Xenon lights with auto levellers.
So to complete the setup I assume I need to order the following parts ?
Headlight washer loom - Part number not yet identified.
Pump for headlight washers £47.58 - 3B7 955 681 also N903 038 01 this is the O-ring for the pump
Gasket - 431 955 465A
Lift Cylinder - 1K6 955 978A x 2
Speed nuts - n909 591 01 x 4 - 2 per cylinder
Nozzle carrier Left - 1K6 955 103
" " " Right - 1K6 955 104
Cover cap Left - 1K6 955 109 GRU
" " Right - 1K6 955 110 GRU
If cover caps are required I will order the primed ready for paint variants
Left = 1K0 807 717 B GRU
Right = 1K0 807 718 B GRU
Adaptor - 1T0 955 665
Connector - 1J0 955 665E x 3
Hose in 10m length - 1J0 955 964F
Angled piece - 1J0 955 665A
Junction - 7L6 955 873
Terminals - 1J0 955 846 x 8
Cable tie with terminal socket - 3D0 971 838E x 1
Washer bottle - 1K0 955 453 S 5.5ltr - £33.48
Water level switch - 7M0 919 376
O ring - 7M0 919 382
Flat contact housing - 7M0 973 202
I will update costs as I go along
![scared :scared:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/scared.gif)
Thanks All
![happy2 :happy2:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/happy2.gif)
