Author Topic: scirocco Speedo In MK5 Golf 1.9 Tdi 2004  (Read 7505 times)
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« on: April 22, 2014, 07:14:30 pm »
ive seen that a couple of people have sucessfully retrofitted a set of scirocco clocks in to their mk5 golf
what does this entail and how much work is it to get it working correctly
thanks  :smiley:
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline xjay1337
  • -Receive: 377
Re: scirocco Speedo In MK5 Golf 1.9 Tdi 2004
« Reply #1 on: April 22, 2014, 07:21:39 pm »
Speak to Eddie.
I have seen it first hand in a 05 2.0 TDI that a guy had done himself, he was polish, he fitted my GTI US cluster for me.
He said it was a pain in the arse to get the ABS stuff to work properly.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #2 on: April 22, 2014, 07:36:04 pm »
I think nick over on R32OC ha either Rocco or mk6 clocks in his I'll try and find a link
Offline Nodz
  • -Given: 73
  • -Receive: 103
Offline J400uk
  • -Receive: 27
« Reply #4 on: April 22, 2014, 08:14:04 pm »
Very impressed with that above link, I didn't think it was possible to fit BAP (white screen) clocks to Mk5 era red-screen cars.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #5 on: April 22, 2014, 08:17:53 pm »
I read somewhere he was looking into a colour screen next
Offline xjay1337
  • -Receive: 377
« Reply #6 on: April 23, 2014, 12:44:29 am »
http://www.r32oc.com/topic/47115-a-uk-1st-scirocco-r-clocks-in-my-mk5-r32-sweeping-needles/
I'm sorry but this wasn't the first as I saw it done towards the end of Summer 2012.
Well, okay, first Scirocco R cluster
The ones I mentioned were Scirocco TDI R-line cluster , I can only presume it's similar to the 'Rocco R petrol ones.
Taken a pic from  his car which was working
Working with steering wheel controls, with immobilisor active and functioning correctly
a very good mod but IMO needs the rest of the interior lighting changing to match.
Offline kalu
« Reply #7 on: April 26, 2014, 11:57:58 pm »
thanks  :smiley:
You need the clocks, wiring loom adapter, late gateway and if your car is pre 2007 then you may need to swap your ABS controller for a later type one.
Also, you will need to change the transponders in your keys and then its possible to code them to the MK5.
Offline vrod
« Reply #8 on: May 06, 2014, 09:29:50 am »
I did not need to swap my abs controller and mine is a 12/2006. If your car is from before 2008 though, you need new immo-devices. If you are willing to drive to Poland (or send your current cluster and be without car for 2-3 weeks) to get it done, I know a guy which are super crazy at this. He did a fantastic job with my premium cluster and he's also a very friendly guy.
Offline kalu
« Reply #9 on: May 06, 2014, 10:38:51 pm »
You don't always need to change it, it depends which version is fitted!
