Author Topic: MK6 GTD - Cruise Broken  (Read 2124 times)
Offline Betty02
    • iBett
« on: April 26, 2014, 10:38:58 am »
Got a 10 plate GTD, and the cruise stopped working not long after a service. Driving at 75, stuck it on and it just wet off. red explanation point? Just got car back from having a new turbo actuator, it's only done 54k :/ Any ideas on what to look for on the cruise? No ABS lights?
ADMIN NOTICE: Please do not use the site for advertising!
Offline omeydz
  • -Receive: 50
Re: MK6 GTD - Cruise Broken
« Reply #1 on: April 26, 2014, 12:23:16 pm »
Try and clear faults with vagcom. If no luck then cruise switch is probably faulty and need changing of the indicator stalk.
If you got the car fixed at dealers id take it back saying cruise worked before the repair and doesnt now and get them to diagnose it.
Good luck!
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline Betty02
    • iBett
« Reply #2 on: April 27, 2014, 12:19:56 pm »
This is the strange thing, Nothing in VCDS, no errors or nothing! Got a specialist to have a little look and he said the signal is definitely leaving the stalk but then stopping at it's next port of call but he's not sure what that is. I have been reading up and could be something as simple as a Brake Switch? I can grab a new one of these for £8. Anyone any ideas where it's located?
Offline doylebros
  • -Receive: 310
« Reply #3 on: April 27, 2014, 01:07:02 pm »
If you test it with VCDS (in advanced measuring blocks) you'll be able to check all the stages from the CC switch to brake light and clutch switch before pulling anything to pieces.
Offline doylebros
  • -Receive: 310
« Reply #4 on: April 27, 2014, 01:19:52 pm »
I assume you've checked for no blown fuses?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: April 27, 2014, 07:40:57 pm »
take the stalk apart, the plastic sliding contact has come off the runner
Had the same issue last week
Cluster and Key coding
Location Great Yarmouth
Offline Betty02
    • iBett
« Reply #6 on: April 28, 2014, 05:14:39 pm »
Eddie - if the stalk was broken then surely they wouldn't be able to record a signal leaving the stalk? Maybe they can still not sure, I will try get another stalk to temp plug in and test!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: April 28, 2014, 05:26:39 pm »
it is the switch on the top
the rocker on the end will still function
