Author Topic: Boost Problem - (**New Picture added Pg2 - Please have a quick look**)  (Read 6620 times)
Offline GTI-Ross
  • Learning All The Time :)
Hey up fellas,
Thought I would get some use out of my VAG-COM today. Decided to pop out and do some quick 3rd gear pulls, unfortunately I couldn't get a clean pull to the redline before it started to rain, but this graph gives a good idea what its requesting and what im getting, or in this case what im not getting...
Floored it at around 3100 RPM.
Its a MK6 GTI Revo Stage1 - Is it down to an OEM HPFP why its not making specified amount? All info welcome
*Edit - N75 and another boost graph on page 2*
« Last Edit: May 04, 2014, 11:09:21 am by GTI-Ross »
Offline Markyed30
Re: Logging Boost with VAG-COM - See my Graph - Page 1
« Reply #1 on: April 27, 2014, 10:44:59 pm »
Boost leak?
Offline GTI-Ross
« Reply #2 on: April 27, 2014, 11:07:54 pm »
Boost leak?
DV and all pipes are fine. PCV valve was changed about 2 months ago. Hard to see it been that. Any other ideas?
What the max boost its should be able to hold for a period of time. Dont get me wrong it pulls hard for a stage 1 - 276bhp.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: April 28, 2014, 11:52:31 am »
Have you checked the pipe that joins the turbo to the intercooler?
It's common for this to leak, and it's a cheap fix. Look for an oily mark on the undertray beneath it.
Other than that I'm out of ideas. Could be a small crack in the turbine housing, but that is unlikely
« Last Edit: April 28, 2014, 12:01:08 pm by GrayMK5GTI »
Offline GTI-Ross
« Reply #4 on: April 28, 2014, 11:58:37 am »
It's common for this to leak, and it's a cheap fix. Look for an oily mark on the undergrad beneath it.
No i havent checked that, you got a picture or a part number please?
Do you think it should match the requested boost and keep matching all the way on stock parts?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #5 on: April 28, 2014, 12:00:35 pm »
Part for the ED30 is here: http://www.mk5golfgti.co.uk/forum/index.php/topic,81510.0.html
Not sure if it's the same for the mk6 though.
It's at the left side of the engine by the alternator  :happy2:
Offline GTI-Ross
« Reply #6 on: April 28, 2014, 12:05:24 pm »
yeah, i will deffo check that out. Just need to find out if its the same part number for MK6. Cheers bro
Offline JMP
« Reply #7 on: April 28, 2014, 01:35:53 pm »
I think its just due to the fact the revo is mapped aggressively to maximise power delivery in any car. They request more boost then cars can generally produce. If you have dynoed the car with great numbers, theres nothing to worry about.
What are your boost-timing-fuel settings? Usually these are setup, so that the gap between request and delivery is as small as possible. This way you will get all the boost you can, without the car trying to push extra. I would drop the boost down a bit.
« Reply #8 on: April 28, 2014, 03:50:02 pm »
Log it again with the N75.
Offline GTI-Ross
« Reply #9 on: April 28, 2014, 04:38:20 pm »
what does N75 show? is that MB 114?
Offline xjay1337
  • -Receive: 377
« Reply #10 on: April 28, 2014, 04:44:17 pm »
duty cycle % i think.
Offline martziniuk
« Reply #11 on: April 28, 2014, 05:55:47 pm »
Block 118
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline biffobear
« Reply #12 on: April 28, 2014, 06:38:34 pm »
i had the same problem, checked and changed usual parts, I did notice a different smell from the exhaust(burnt) , renewed full exhaust system problem solved, cut up the downpipe, one of the cats was damaged
Offline arris
« Reply #13 on: April 28, 2014, 06:54:55 pm »
How do you do a log like this with vag com?
Offline GTI-Ross
« Reply #14 on: April 28, 2014, 08:45:15 pm »
Block 118
What does it measure that 115 doesnt, and what can i gain from the data, thanks
