April 15, 2025, 04:23:38 am
All Things Mk5
Technical Workshop
HPFP Torque setting
Topic: HPFP Torque setting (Read 10985 times)
Tfsi_Mike
Just look at my post count
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
HPFP Torque setting
April 28, 2014, 08:14:12 pm »
As per the title has any one got the torque setting for the three 2.0 TFSI HPFP bolts?
Thanks in advance people.
Mike
bacillus
-Given: 4
-Receive: 451
Re: HPFP Torque setting
Reply #1 on:
April 29, 2014, 08:18:20 am »
According to APR it should be tighten to 15Nm.
http://www.goapr.com/support/fsi_fuelpump_installation.pdf
anorganix
HPFP Torque setting
Reply #2 on:
April 29, 2014, 09:05:09 am »
Torque the three bolts holding the pump to the head to 10Nm. Tighten the union nut on the fuel line to 25Nm.
If equipped, tighten the banjo bolt to 17Nm.
Last Edit: April 29, 2014, 09:07:49 am by anorganix
bacillus
-Given: 4
-Receive: 451
Reply #3 on:
April 29, 2014, 09:12:52 am »
You're right ^^, it is 10Nm!
I inadvertently quoted the low fuel pressure sensor torque from that pdf.
Tfsi_Mike
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Reply #4 on:
April 29, 2014, 09:16:35 am »
Very helpful, cheers!
Should be added to changing cam follower guide
What is thought to be the better fuel line to have; the rubber left hand line or the steel one?
bacillus
-Given: 4
-Receive: 451
Reply #5 on:
April 29, 2014, 09:48:00 am »
The rubber line is the later revision and is better as it allows easier changing of the cam follower.
Tfsi_Mike
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Reply #6 on:
April 29, 2014, 09:53:34 am »
I have the rubber one. Going to replace the spring clip as it's a bit rusty
All Things Mk5
Technical Workshop
HPFP Torque setting
Jump to:
===> Technical Workshop
