Author Topic: Changing Brake Fluid  (Read 4061 times)
Offline Dallen75
« on: May 08, 2014, 10:45:15 pm »
Hi all, looking at installing my new suspension and discs, pads etc next week and was wanting to change the brake fluid, any idea in litres how much I will need please ? Cheers Davey
Offline bacillus
  • -Receive: 453
Re: Changing Brake Fluid
« Reply #1 on: May 08, 2014, 11:12:48 pm »
If you're going to bleed the abs pump then I would get 2 litres.
Offline iian
« Reply #2 on: May 08, 2014, 11:18:06 pm »
As above, get a few litres to be safe.
No harm in having some decent spare brake fluid lying around either.
Offline doylebros
  • -Receive: 310
« Reply #3 on: May 09, 2014, 06:16:34 pm »
This is worth a read
http://www.myturbodiesel.com/wiki/brake-fluid-and-clutch-bleeding-and-flush-mk5-vw/
Offline Dallen75
« Reply #4 on: May 09, 2014, 11:36:13 pm »
Just had a good read through ! Very detailed just what was needed cheers !
Offline GunnerGibson
« Reply #5 on: May 11, 2014, 02:29:58 pm »
DIY fluid replacement can lead to disaster... I can remember my mate making an error and struggling to remove air from near his ABS block.. on VAGcom their is an option to run the ABS pump to pump through the fluid-prob covered in the above link.
Offline Dallen75
« Reply #6 on: May 12, 2014, 10:40:49 am »
Yeah I've decided to let my local Indy do this instead of me wasting time and effort on not doing it correctly, then having to ring them. Lack of knowledge in my case could turn out to be a serious mistake so I'd rather pay a few quid and have peace of mind !
Offline teginder81
« Reply #7 on: May 12, 2014, 12:22:32 pm »
I have Castrol Performance 5.1 or something ridiculously expensive (circa $150/litre)
