Author Topic: Tyre Pressure Monitor  (Read 3539 times)
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
Re: Tyre Pressure Monitor
« Reply #15 on: May 09, 2014, 12:40:08 pm »
Had no idea there was a DIY wireless system. I may have to look into it...!
Does anybody remember many years ago when BMW ran its April Fool advertisement presenting an in-car tyre pressure monitoring system and we all laughed at such an impossibly silly idea?!  Not so silly now eh?
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #16 on: May 09, 2014, 03:55:10 pm »
Have to say my OEM monitor has worked well for me in the past. It has alerted me to slow punctures before the pressure has dropped too much. Obviously you have to reset it whenever you top up tyre pressures to keep it accurate though.
Seem to remember something in the handbook about about it needing to be replaced after 6 years though. I wonder if anyone has done this, I know I haven't!
'16 MK7 Golf 1.4TSI Match Edition
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #17 on: May 09, 2014, 04:16:08 pm »
Not sure how you can replace it, as it's essentially the ABS system monitoring wheel rotational speed and calculating against steering angle sensor and the other wheels. A deflating tyre rotates faster than an inflated tyre, so the system sees one wheel traveling faster than the others and reports a puncture.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #18 on: May 09, 2014, 08:02:44 pm »
Yeah I know, I thought it was strange. I checked the manual though and in the service section it defo says it needs replacing after 6 years.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #19 on: May 10, 2014, 12:31:03 am »
Are you sure it isn't talking about the puncture repair bottle of snot? That needs replacing after a certain number of years.
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #20 on: May 10, 2014, 03:35:16 pm »
No it's not that stuff. Here's a piccy:
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #21 on: May 10, 2014, 03:38:19 pm »
That reads like a different system. There are no tyre pressure sensors on mine, it's just a monitoring system rather than a pressure sensing system. Perhaps they have a 4 wheel valve pressure system on some higher spec cars?
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #22 on: May 10, 2014, 03:45:12 pm »
Yarp, maybe that's it then.
  • -Given: 380
  • -Receive: 442
« Reply #23 on: May 11, 2014, 11:58:35 am »
Surely if your Golf has a button alongside the ESP row of buttons in front of the gearstick, then your car has tyre pressure sensors?
Volkswagen do revise their build specs every June/July. So not all GTI's have exactly the same detail spec.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #24 on: May 11, 2014, 12:37:55 pm »
No they don't have pressure sensors. The system works on rotational speed of the wheels which is monitored by the ABS system.
Offline DDM
« Reply #25 on: May 11, 2014, 01:03:51 pm »
i got it retro fitted my eddie on ours and it works spot on, had a puncture on the front drivers tyre and it picked it up when the pressure had dropped to 22psi.
Offline Shaw
« Reply #26 on: May 11, 2014, 03:48:08 pm »
My pressure warning system is crazy picky. Will light up if a tyre drops 7-8psi. More so on the front wheels.
'07 Mk5 GTI Manual
Offline ILoveTuna
« Reply #27 on: May 11, 2014, 05:21:41 pm »
I spotted a tyre pressure option in vcds somewhere. Mine was unchecked?
I have the ABS system so I think this option must be if pressure sensors are fitted?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #28 on: May 11, 2014, 06:44:59 pm »
No, you need the button to reset the system, wiring to suit, and then coding via VCDS.
  • -Given: 380
  • -Receive: 442
« Reply #29 on: May 12, 2014, 11:04:43 am »
....If the rest of the system is present isn't the coding activated by default from the VW factory?
