Author Topic: S3 front brake query  (Read 1753 times)
Offline SurreyED30
« on: May 11, 2014, 04:39:24 pm »
Hi all
Just wondering what's the biggest disc that will fit under the s3 calipers?
I currently have the oem 345mm vented discs, just wondered if I could run bigger diameter disc with the S3 calipers?
My discs
Jake
Re: S3 front brake query
« Reply #1 on: May 11, 2014, 04:44:16 pm »
345mm are the biggest IIRC
Offline SurreyED30
« Reply #2 on: May 11, 2014, 04:49:41 pm »
Wanted bigger discs with out spending ££££ on a aftermarket BBK but guess I'll just have leave the 345 and maybe get some drilled discs  :happy2:
Offline TommyR
  • -Receive: 20
  • Black Edition 30
« Reply #3 on: May 11, 2014, 04:53:00 pm »
As above pretty sure there the biggest. So if you are feeling flush and wanting better brakes you could get ttrs/rs3 calipers and a fitting kit to run on your 345's :happy2:
Offline SurreyED30
« Reply #4 on: May 11, 2014, 05:07:28 pm »
Not feeling massively flush at the moment, had my insurance renewal in April plus a sh*tter of a trip to the garage with a incorrectly fitted engine mount bracket, bye bye £1400 in 5 weeks  :sad1: :sick: I have nothing to show for it other than a few pieces of paper from the insurers  and a ' correctly ' fitted engine bracket  haha new set of drilled discs is my limit for braking at the movement
« Last Edit: May 11, 2014, 05:09:50 pm by SurreyED30 »
« Reply #5 on: May 11, 2014, 05:09:03 pm »
Just get some good pads and discs... they will stop just fine.
Offline SurreyED30
« Reply #6 on: May 11, 2014, 05:11:13 pm »
What's discs do you have with your s3's rich ? My pads are good there ferodo and fitted in December with plenty of meat in them still
« Reply #7 on: May 11, 2014, 05:14:11 pm »
340mm TTS discs. bit lighter and better venting that r32 discs.
Mintex 1144 or 1155
Pagid blues
Project mu... 300+ quid  :scared:
Ive never felt the need to upgrade my brakes past these...and it gets driven fairly hard. On track it would be a different story I would imagine.
Offline SurreyED30
« Reply #8 on: May 11, 2014, 05:18:58 pm »
Thanks  :happy2:
I'm not planning on tracking it, well maybe once in the future.
We're the tts a direct fit then?
« Reply #9 on: May 11, 2014, 05:26:29 pm »
yes  :happy2:
they are about 1-2kg a corner lighter, cant remember exactly
Offline SurreyED30
« Reply #10 on: May 11, 2014, 05:47:37 pm »
Thanks mate surfing the net + fleebay now  :happy2:
Offline skard
  • -Receive: 245
« Reply #11 on: May 11, 2014, 05:48:27 pm »
I got TTS discs from ECP with discount for £92 a pair
« Reply #12 on: May 11, 2014, 05:55:14 pm »
http://www.opieoils.co.uk/pv-100335-brake-disc-for-1-wheel-single-vented-disc-premium-uv-painted-brembo-09977111-single-disc.aspx
Those are the ones you want... annoyingly they were 103 quid a pair over xmas with a deal they had going on. :smiley:
Offline Softishman
« Reply #13 on: May 11, 2014, 07:56:29 pm »
So the TTS 340mm disc fit directly on Golf mk5 with R32 calipers? I am going to upgrade my brakes on my eddy soon...
Offline SurreyED30
« Reply #14 on: May 11, 2014, 10:26:15 pm »
Thanks rich, will get some ordered for sure at that price  :happy2: update next weekend  :P
