Author Topic: Head liner side trim removal  (Read 3085 times)
Offline N44LED
« on: May 20, 2014, 11:53:46 pm »
Hi guys
Just wondering of there is any guides on how to remove the side trims really. As iam trying to install the dab aerial wire.
Aled
Offline L17JDH
Re: Head liner side trim removal
« Reply #1 on: May 21, 2014, 07:17:04 am »
I know the b pillar trims you have to remove the airbag badge and there is a torx screw behind it then it should just pop of.
I hope this is of some help to you.
Standard black vw golf mk5 gti 2005 // evoms intake, miltek cat back, pre-cat delete, r-tech stage 1 remap, Mercedes alphards, kw coilovers.
Offline paulw123
  • -Receive: 47
« Reply #2 on: May 21, 2014, 10:59:44 am »
The C pillar trim needs pulling out at the top (bolt under airbag logo), then the roof lining will drop enough to pass the wire through. I took the outer fakra plug bit off to make the cable end smaller to pass through.
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
« Reply #3 on: May 21, 2014, 01:17:05 pm »
What these guys have said but there are few workshop manuals on here if you search about.
The manuals will show you what directions to pull them in to minimize damage.
:grin:
Offline J12spk
  • VW PERVERT
« Reply #4 on: May 21, 2014, 07:28:02 pm »
If u do it then be careful when refitting as I lost the screw behind all the other internal panels! Not sure what size it is to replace either!
Das Auto
Offline sootpig
« Reply #5 on: May 21, 2014, 08:12:10 pm »
I removed the panel above the pedals (2 torx screws) the fuse cover and the thin long panel next to this.
 The cable can be tucked under most of the side trim where it meets the carpet without removing.
 C pillar as said remove airbag badge carefully and reuse it This will allow you to tuck the cable behind
 Plastic trim at rear of headlining can be pulled off No screws but be careful not to snap
 You will need small hands if you are replacing the aerial :happy2:
 Just fitted the kinetic  6003 aerial replacing the window effort
Offline doylebros
  • -Receive: 310
« Reply #6 on: May 21, 2014, 08:23:51 pm »
Read step 4 of this guide but the whole guide is good reading!
http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
