Poll
What front brake upgrades are you running?
Upgraded discs/pads (groved/cross-drilled with matching pads)
18 (14.9%)
Larger OEM R32/R20/S3/Cupra
47 (38.8%)
4 pot calipers
36 (29.8%)
6 pot calipers
10 (8.3%)
Beyond dreams (e.g. Lambo/R8 brakes)
10 (8.3%)
Total Members Voted: 121
Author Topic: POLL: War of the brakes  (Read 58982 times)
Offline th3_f15t
  • -Receive: 183
Re: POLL: War of the brakes
« Reply #135 on: July 12, 2014, 01:01:24 am »
What sort of price am I looking at?
Offline TommyR
  • -Receive: 20
  • Black Edition 30
« Reply #136 on: July 12, 2014, 06:44:42 am »
I bought mine as part of a kit so unsure on price but get in touch with Monte on here, as just after I had bought mine he offered me a brand new set of Brembo 340's for a £100 :happy2:
Offline th3_f15t
  • -Receive: 183
« Reply #137 on: July 14, 2014, 09:11:55 pm »
I know they're ridiculously more pricey than the Audi TTS discs, but just seen these;
http://www.psituning.com/product.php/23217/ecs_front_cross_drilled___slotted_2_piece_brake_rotors___pair__345x30____30__lighter__mk5_r_mk6_r
Thoughts/Opinions?
Offline th3_f15t
  • -Receive: 183
« Reply #138 on: July 23, 2014, 07:21:25 pm »
Casual bump to get more votes.
Offline xjay1337
  • -Receive: 377
« Reply #139 on: July 30, 2014, 06:35:59 pm »
Thoughts/Opinions?
Hahahahahaha 550?
You can buy a bbk for that!
I'm ooot.
« Reply #140 on: July 30, 2014, 06:45:32 pm »
Find me a bbk for that money please jay.
Offline th3_f15t
  • -Receive: 183
« Reply #141 on: July 30, 2014, 08:04:24 pm »
I did notice that price. Think you can source a set of used Porsche 4-pots for that and as long as you don't mind used parts (without refurb) then it's the same price to not only save weight but also increase braking power!
Offline Laurence
« Reply #142 on: July 31, 2014, 12:17:39 pm »
Do you have to run uprated master cylinder when upping the caliper size?
Offline th3_f15t
  • -Receive: 183
« Reply #143 on: July 31, 2014, 12:35:30 pm »
Not really, I don't think. The OEM and 4 piston caliper upgrades work perfectly well with the OEM master cylinder. Even the 6 piston calipers work fine, but people are looking towards to an Audi TTRS master cylinder when they go to this level of braking.
Offline th3_f15t
  • -Receive: 183
« Reply #144 on: August 18, 2014, 07:17:03 pm »
Right, I need to clear something up here...
Can you run Audi TTRS 4 piston calipers with DaveB1970 brackets with 340 Audi TTS J hook discs without using spacers on a mk5 Golf GTI with 18" alloys (BBS CH with an of ET45 if that helps)? Also what's the sort of price I'd be paying for a kit, all brand new?
« Reply #145 on: August 18, 2014, 07:18:47 pm »
Doubtful. 10mm spacer probably
Offline th3_f15t
  • -Receive: 183
« Reply #146 on: August 18, 2014, 07:22:13 pm »
Damn, as I think pushing my wheels out 10mm will start to cause issues with the arch. Are there any kits that work without spacers? Seen an AP Racing 4 piston set up that claims to not need spacers, but again I'm assuming this is down to clearance of the alloy over the caliper?
Offline vRSAlex
  • -Receive: 253
« Reply #147 on: August 18, 2014, 07:25:59 pm »
5mm will be fine.  I will be doing 3mm and 5mm spacer kits with hub extenders soon.
Follow AKS tuning on Facebook
Offline th3_f15t
  • -Receive: 183
« Reply #148 on: August 18, 2014, 07:26:54 pm »
Hub extenders..? Explain to us simple folk what these do please...
Offline vRSAlex
  • -Receive: 253
« Reply #149 on: August 18, 2014, 07:31:37 pm »
Was going to try and be funny and just say 'they extend the hubs'  :P
It's an alloy insert that is fitted into the end of the hub collar, to extend the collar which then allows the wheel to be seated on a 'fake' section of the hub.
