Poll
What front brake upgrades are you running?
Upgraded discs/pads (groved/cross-drilled with matching pads)
18 (14.9%)
Larger OEM R32/R20/S3/Cupra
47 (38.8%)
4 pot calipers
36 (29.8%)
6 pot calipers
10 (8.3%)
Beyond dreams (e.g. Lambo/R8 brakes)
10 (8.3%)
Total Members Voted: 121
Author Topic: POLL: War of the brakes  (Read 58858 times)
Offline Biano44
  • The CC GT 200
Re: POLL: War of the brakes
« Reply #150 on: August 18, 2014, 07:33:21 pm »
I had mine fitted today.......PHE.....NO.....MEN.....AL!!!!
I think what Alex means by hub extenders is 3/5mm spacers that are hub centric or similar. But I could be wrong.
Turns out I was wrong but not by much.
Offline th3_f15t
  • -Receive: 183
« Reply #151 on: August 18, 2014, 07:34:18 pm »
Shh you, looking at your project was the cause of these thoughts to enter my mind!
Offline vRSAlex
  • -Receive: 253
« Reply #152 on: August 18, 2014, 07:38:59 pm »
Looks great.
You cant get hubcentric 3/5mm spacer as there isn't enough internal room for the hub to sit into.
Follow AKS tuning on Facebook
Offline Biano44
  • The CC GT 200
« Reply #153 on: August 18, 2014, 07:42:23 pm »
Its totally worth it......I'd be quick though as when I asked Alex last week he only had one fitting kit left and it wouldn't surprise me if its gone already.
My mechanic asked me today "how much?". Everyone will pay a different price. I managed to find calipers that were quite cheap (Thanks Alex for the tip), the TTS discs are quite cheap and you could put regular Pagid pads in (but opted for RS4-2's) and the fitting kit is £250ish. All add's up to quite a few £'s.
Obviously you can go nuts and have floating discs and better pads but it's all up to you.
They look better, brake better, better feel under the foot with more control, and are lighter than normal GTi brakes so will be loads lighter than S3 brakes......Just ask MR Wigley how heavy they are!  :signLOL:
Offline Biano44
  • The CC GT 200
« Reply #154 on: August 18, 2014, 07:44:04 pm »
Looks great.
Thanks Alex.
Offline TommyR
  • -Receive: 20
  • Black Edition 30
« Reply #155 on: August 18, 2014, 08:50:02 pm »
Right, I need to clear something up here...
Can you run Audi TTRS 4 piston calipers with DaveB1970 brackets with 340 Audi TTS J hook discs without using spacers on a mk5 Golf GTI with 18" alloys (BBS CH with an of ET45 if that helps)? Also what's the sort of price I'd be paying for a kit, all brand new?
On an oem offset wheel so ET51 I needed a 12mm spacer to just clear the caliper and in regards to cost, for everything new it's £1200 for the kit.
https://m.facebook.com/AKStuning/photos/pb.124288387696681.-2207520000.1403955248./428082620650588/?type=3&theater
Offline th3_f15t
  • -Receive: 183
« Reply #156 on: August 18, 2014, 08:58:40 pm »
Cheers guys. Once my other outstanding mods are sorted and the scrap yard of stock parts is shifted I'll look to getting a TTRS kit I reckon before going stage 2.
Offline audiman
« Reply #157 on: August 19, 2014, 07:25:34 am »
I'm running stg2+ on my ed30. Running stock rear brakes and TTRS front discs and calipers! MIT feels amazing even with oem pads.
Mk5 GTi ED30 - 360ps
B7 RS4 supercharged - 650ps
Mk2 GTi 4motion 1.8T - 450ps
« Reply #158 on: August 19, 2014, 08:44:34 am »
My old ED30 brake set-up. Tarox 10 pots.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #159 on: August 19, 2014, 10:12:14 am »
which IMO is not for the road, extremely noisy and although the brake well they generate a lot of heat. This how they looked after track use
And the results of they heat they generated
Over the top mod list ;o)
Offline th3_f15t
  • -Receive: 183
« Reply #160 on: August 19, 2014, 11:49:52 am »
That's just ludicrous! :mad:
Offline vRSAlex
  • -Receive: 253
« Reply #161 on: August 19, 2014, 03:19:12 pm »
A Tarox seal kit costs as much as the calipers!
Pads are even worse.  One of the 6 pot kit uses a pad from a Ford Cargo van.
After using Tarox before, they are not something I would go back to.
  • -Given: 243
  • -Receive: 155
« Reply #162 on: August 19, 2014, 03:33:43 pm »
Same here Alex  :happy2:
Offline th3_f15t
  • -Receive: 183
« Reply #163 on: August 19, 2014, 08:02:16 pm »
Think we should have some more pictures of 6, 8 and 10 piston calipers and setups. You know, for reference and all that...
« Reply #164 on: August 19, 2014, 08:37:39 pm »
Here's a Cayenne BBK for the back end. Lusted over these (pics below) a few times over the years
