Author Topic: R32 Anti Rattle Clips  (Read 5338 times)
Offline bluo
« on: July 03, 2014, 03:26:41 pm »
So I had my bigger brakes brakes fitted and decided the unfinished anti rattle clips looked all wrong...
I the bought some others and had them powder coated black...
My question is: Is there a tool to remove and fit these clips and if not is there a method of removing them and fitting them without damaging or scratching the CALIPER and now in this case the clips??
Offline xjay1337
  • -Receive: 377
Re: R32 Anti Rattle Clips
« Reply #1 on: July 03, 2014, 03:26:59 pm »
Just use a screwdriver.
Offline bluo
« Reply #2 on: July 03, 2014, 03:28:31 pm »
Yeah with a rag, got that but trying to find a way of removing them and fitting them without having to touch them up after!
Offline bigmig95
  • -Receive: 50
« Reply #3 on: July 03, 2014, 04:40:49 pm »
Stick a cable tie round one end when installing and use a screwdriver on the other.  They can hurt a lot if you don't retain them somehow  :happy2:
Offline bluo
« Reply #4 on: July 03, 2014, 08:15:40 pm »
Surely there's a way of doing it without chipping the paint!?
Offline bluo
« Reply #5 on: July 05, 2014, 10:31:56 pm »
Done...
Cable ties are magic!!!
Offline Beddie
  • -Receive: 76
« Reply #6 on: July 05, 2014, 11:00:25 pm »
Result! No paint chips then?  :happy2:
I'll have to pinch the cable tie method as need to fit mine on freshly painted calipers too, any tips lol!  :laugh:
Carbon Grey Edition 35 - Here
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #7 on: July 06, 2014, 08:37:47 am »
 :happy2: :happy2:
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Online Andy
« Reply #8 on: July 06, 2014, 11:13:13 am »
can be difficult to get back in but I did the cable the method also
Offline bluo
« Reply #9 on: July 06, 2014, 12:33:11 pm »
Got a couple small ones when removing the old clips... Cable tie the lower arm tight then put a tie on the upper arm and pull that as far as it can go. Then put another tie on the upper arm and while pulling that tight push the centre inward and it should just pop in place.
Touch up and scuffs and off you go!
Offline bigmig95
  • -Receive: 50
« Reply #10 on: July 07, 2014, 04:59:36 pm »
No scuffs on mine  :happy2:
