Author Topic: Rear view camera and ops issues  (Read 1504 times)
Offline Pashka
« on: July 21, 2014, 02:58:07 pm »
Hello, I have RCD510, rear ops and had scirocco low line camera installed. The main problem is that I don't see both camera and ops on the same time like in the pic.
Everytime I have to push button between ops and camera. If I change park assist coding to 30... the main screen is camera and there is the empty gap for OPS, if 10... main is OPS. Any ideas how to make both? :drinking:
Mine is like this at the moment.
« Last Edit: July 21, 2014, 03:26:14 pm by Pashka »
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline doylebros
  • -Receive: 310
Re: Rear view camera and ops issues
« Reply #1 on: July 21, 2014, 08:15:47 pm »
I would check the coding for the OPC on the Module (from memory module 10) with VCDS.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #2 on: July 21, 2014, 08:29:41 pm »
I don't suppose it's helped by the fact that you appear to have a chinese RCD 510. They're less functional then the UK spec ones.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
