Author Topic: rvc screen not working.  (Read 3664 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re:
« Reply #15 on: August 01, 2014, 11:56:55 am »
I dont think it may be a power issue as you said the camera does flip open so the reverse signal is working.  May be the coaxial cable. I would trace the wire to ensure there arent any kinks in it anywhere.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: rvc screen not working.
« Reply #16 on: August 01, 2014, 06:14:03 pm »
Does the badge mech and the camera run off the same power source then? Or does the camera need another power source to turn it on? My camera didnt need a permenant feed but it is a bumper version
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #17 on: August 01, 2014, 06:46:25 pm »
Had a problem like this and it turned out to be the 2760? firmware I had downloaded. Tried downloading from a different site and undated which solved the problem.  :happy2:
Offline doylebros
  • -Receive: 310
« Reply #18 on: August 01, 2014, 07:31:11 pm »
Camera needs a permanent live.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re:
« Reply #19 on: August 01, 2014, 08:30:59 pm »
The camera needs a permanent so that you can use it to open the boot
Offline apples12
« Reply #20 on: August 02, 2014, 10:10:16 am »
when i had this problem it was because the yellow trigger wire on my loom wasn't making a good enough connection with the reverse light...
MK6 GT TDI  - CW - LUX pack
GONE
MkV Golf 1.9TDI Sport in DBP, 160,000 miles and climbing!
Retrofits by me:GT front end,OEM bixenons with auto-levelling/washers, Valeo LED Rears, MFSW + Highline SWCM, Cruise Control, 30byte Highline CECM, Highline clocks, Rain/Light Sensor, Auto-dimming Rear view Mirror, RNS-510 LED (Ver H; SW: 4020), Fiscon Basic Bluetooth, MDI + Aux, Armrest, Reverse Camera LOW, TPMS..what next...
Offline Kev
« Reply #21 on: August 04, 2014, 08:19:41 pm »
Ill check the things you have all sugested and let you all know soon thanks lads im sure it was a permenant live I put it to therse only 2 spare fuse ports to put another circuit into. :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #22 on: August 06, 2014, 01:48:11 pm »
if it works of a switched live then you must have wired it to a switched live
Boot should open all the time
Cluster and Key coding
Location Great Yarmouth
