December 21, 2025, 03:42:45 pm
All Things Mk5
How to Guides / Troubleshooting
Edition 30 vibration
Topic: Edition 30 vibration (Read 3646 times)
flyboy1976
Always Involved
-Given: 25
-Receive: 15
October 29, 2009, 05:44:13 pm »
Please can anyone come up with any ideas what my problem maybe.I am experiencing a knocking vibration sound that occours when im on the biting point of the clutch. When im in 1st or reverse typically it gets worse when you put the car under more load i.e with the handbrake is applied.i have been on other forums and found a few gti mk5 guys with eaxactly the same issue but no resolution.my dealer has already put a new clutch kit and dual mass flywheel in the car which has made it slightly better.can anyone help? It doesnt happen any other time other than when you are in that small area of travel on the clutch pedal with a gear engaged and have found the biting point and are almost cleared the transition point on the clutch.Has anyone else experienced this issue or even better solved it????
Thanks in advance
WhiteGTI
Just look at my post count
-Given: 29
-Receive: 22
F-A-S-T
Re: Edition 30 vibration
Reply #1 on:
October 29, 2009, 05:52:58 pm »
Isn't that just a normal characteristic of a dual mass flywheel? Mine feels the same, but have been assured by both dealers (whom i dont usually trust anyway) and more importantly a couple of tuners that it was normal..
2006 E46 BMW M3 - 343hp
vwrascal
-Given: 21
-Receive: 28
If it aint rubbin you aint dubbin
Reply #2 on:
October 29, 2009, 06:05:11 pm »
When depressing my clutch I get a click from the engine, I just turn up the toonage or floor it, this instantly cures the clicking sound. On a serious note, clutch feels fine and works fine so it doesnt bother me
sorry I couldnt be of more help
flyboy1976
Always Involved
-Given: 25
-Receive: 15
Reply #3 on:
October 29, 2009, 06:39:33 pm »
yeah ive been told that too,but im just not going to have vw fob me off although my dealer is superb i have to say they have done loads under warranty ,id just like to eliminate this if i could?
john_o
-Given: 136
-Receive: 108
Reply #4 on:
October 29, 2009, 07:57:25 pm »
they do make funny noises !
I have however found that the dogbone mount insert helped a little, then I moved onto VWR lower mount which made a huge difference. the noise doesnt go away but it does change
Red ED35 5dr DSG
BLOG
BUILD
flyboy1976
Always Involved
-Given: 25
-Receive: 15
Reply #5 on:
October 29, 2009, 08:05:29 pm »
ive got the powerflex dogbone insert and you are right it does make a bit of a difference but i spoke to matt at VWR and he said the same about the pukka VWR engine mounts make a huge difference.Thanks for the feedback so far guys
Last Edit: October 30, 2009, 07:52:48 am by flyboy1976
MAT ED30
-Given: 25
-Receive: 82
Vwr fan boy
Reply #6 on:
October 29, 2009, 09:59:46 pm »
come test mine
All Things Mk5
