February 23, 2025, 02:52:07 am
All Things Mk5
Mk5 General Area
362mm drilled discs
Topic: 362mm drilled discs (Read 784 times)
dan930
Just look at my post count
-Given: 0
-Receive: 56
362mm drilled discs
August 08, 2014, 02:33:35 pm »
I'm getting a slight on & off humming noise at around 60-70mph..(only 60-70mph) & sometimes between 40-50mph
My mate told me it might be the drilled discs as air gets through the holes...Aks checked everything out
But all is ok...
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
rich83
-Given: 165
-Receive: 802
My Ride:
Re: 362mm drilled discs
Reply #1 on:
August 08, 2014, 02:34:23 pm »
Sure its not the tyres?
https://www.justgiving.com/thenational3peaks
duncatr
Always Involved
-Given: 1
-Receive: 7
Reply #2 on:
August 08, 2014, 03:21:56 pm »
If its brakes it will change under braking.
Could be many things but tyres would be a good shout!
dan930
-Given: 0
-Receive: 56
Reply #3 on:
August 08, 2014, 04:37:31 pm »
The humming noise started after I fitted the BBK...
MK6 golfR dsg
AKS TUNED
R TECH custom map
rosco07
Always Involved
-Given: 1
-Receive: 2
Reply #4 on:
August 08, 2014, 06:15:03 pm »
Does it happen on throttle as weight is transferred to the rear wheels?
vRSAlex
Admin
-Given: 39
-Receive: 253
My Ride:
Reply #5 on:
August 08, 2014, 06:53:49 pm »
Quote from: dan930 on August 08, 2014, 04:37:31 pm
We also did a wheel alignment at the same time.
Car is perfect so all I can think is pads running close to discs, or tyre noise as supersports are noisy.
Build Thread
www.akstuning.co.uk
- info@akstuning.com - 01234 822324
Follow AKS tuning on
Facebook
All Things Mk5
Mk5 General Area
362mm drilled discs
