Author Topic: Milltek Exhaust Blown  (Read 11949 times)
  • -Given: 380
  • -Receive: 442
Re: Milltek Exhaust Blown
« Reply #30 on: November 12, 2009, 09:05:53 am »
I have the Ed30 Milltek Resonated Turbo back exhaust which has been on the car just over a year.
Just to highlight a point.........
Modifications in many not all cases are not as well developed as OEM fit items (time and/or money dictates this fact)  Dave B and I were talking about aircraft Mods this week, if we fit a Modification, we have to draw up an inspection regime, and usually this takes the form of more frequent and detailed examinations, until we get enough data to form a regime that will mitigate against failure.
The worrying aspect of this fault, and again hats off to Milltek for their response, is the age of the exhaust, and time to failure.
We can surmise poor fit, poor quality etc.  But it just illustrates that an increased inspection regime is required.  Mods, in most cases are not just fit and forget.  Mods also have a cumulative effect, by that I mean that one set of Mods will be more comfortable together, than another.  Eg a hard suspensioned car will transfer loading to other areas, or a set of engine mounts will aid the exhaust, and restrict engine movement and therefore give the flexi etc and easier time.
....Absolutely spot on, Dave!
This is why Milltek will often honour their warranty beyond their formal period and also why cars get invited to their works at Derby for full inspection and analysis before repair/replacement as appropriate. Of course each case is individual and Milltek aren't going to put up with someone just trying to take advantage - Nor should they.
Milltek are continually keen to monitor their products and make improvements - My own car is testament to that process.
For those who don't already know, I don't work for Milltek - They support my car and I support their efforts and we have become good friends.
Dave's advice is spot on - Whether on a ramp at my VW dealer's, VWR, JKM, or anywhere else, I always take the opportunity to check the whole underside of my car and ask the guys to do so with their more experienced eye. We'd all prefer our mods to be fit'n forget but it's again as the balloonist says, it's the dynamic of the whole package.
« Reply #31 on: November 12, 2009, 10:43:29 am »
PG i may have missed it somewhere but which company fitted it wrong.  :chicken:
Offline WhiteGTI
  • F-A-S-T
« Reply #32 on: November 12, 2009, 01:00:20 pm »
My APR did a similar thing!
Just reminded myself that you have the APR RSC system.
Where exactly was it blown?
Did you have to replace it and did Awesome change it under warranty?
It's a worry other's have blown here including Milltek.
I assume you could here it blowing on tick over?
It was blowing just after the flexi, where the two sections bolt together. I didn't get it done at Awesome because I'm located in Berkshire/Surrey. I got it done at Tuningwerkes. They sorted it all out for me yep.
Could not hear it blowing nope. The only way I found out was because my engine check light came on, with the fault code reading the post cat lambda probe. So we had a look at the car up on the ramps and could see a darkened patch around the bolt.
2006 E46 BMW M3 - 343hp
Offline QD MBE
  • -Receive: 102
« Reply #33 on: November 13, 2009, 04:49:06 am »
is it all sorted now?  fitted ok again?
Offline GTIjames
« Reply #34 on: November 14, 2009, 10:57:40 pm »
well its all fixed now - pic of offending pipe with blown flexi metal bit
normal boost has been resumed, my gauge was fluttering at idal and in 4th gear pulls i was spiking then dropping right down and then spiking again this has now has become stable - cant believe what a detrimental effect a blown exhaaust has on performance - only downside is how quiet the car is now  :sad1:
Offline DanGB
  • Different
« Reply #35 on: November 15, 2009, 11:52:09 am »
has anyone read the milltek warrenty statement..
Quote
Q.   Is my exhaust system covered by a guarantee or warranty?
A.   As long as you are the original purchaser, cat-back exhaust systems are covered by a lifetime anti-corrosion and manufacturing defect warranty and hi-flow sports catalysts and downpipes are covered by a 2 year or 80,000km warranty. We do not cover against any modifications made to our product after it has left our factory and also not for unusual use of the parts - for example, the use of Nitrous Oxide (NOS), damage caused by going over a speed bump too fast etc. Our warranties are offered on the understanding that the cars power maybe increased by up to 33% from it's original specification. Modifications made to increase the power beyond this will render the warranty void.
We pride ourselves on our after-sales support and customer service and will look into each case on an individual basis.
All warranty cases should be dealt with by the Milltek appointed distributor from whom you purchased the system. However, if you are dissatisfied with the service of your distributor in response to your claim, you can contact us directly by emailing us at techsupport@millteksport.com.
Please note: Milltek Sport hi-flow sports catalysts are manufactured from the highest quality materials and built with maximum performance and longevity in mind. However, they are designed to work specifically in conjunction with other Milltek Sport products and should not be used on their own (with the OEM exhaust system) or with other manufacturers exhaust systems. If the Milltek catalysts are fitted with non-Milltek exhaust systems, we are unable to provide any guarantee regarding noise quality, fit, performance or warranty against their operation.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
  • -Given: 380
  • -Receive: 442
« Reply #36 on: November 15, 2009, 12:03:57 pm »
....Yes  :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #37 on: November 15, 2009, 02:19:53 pm »
Have now.
There is no getting away from the fact that the flexi is to short - compare it to the OEM.
Stu...
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #38 on: November 15, 2009, 03:07:32 pm »
Have now.
blueflame flexi and oem as you say is much longer.
The shorter flexi on the milltek does appear to be its weak point
Offline markymark
« Reply #39 on: November 22, 2009, 07:04:00 pm »
My exhaust has started blowing now, I just hope its just a leaking joint were its forced itself apart! :scared:
Im getting it checked out this week!
Offline QD MBE
  • -Receive: 102
« Reply #40 on: November 22, 2009, 07:10:20 pm »
Nooooooooooo!  Hope it is not the flexi going.  If it is, it may persuade Milltek to take a look at their design.
:sad1:
Offline markymark
« Reply #41 on: November 22, 2009, 07:13:03 pm »
:sad1:
Yeah I hope its just blown itself apart at a joint as its only been on the car since February! The joints were tacked when we put it on but you never know it may have come apart! :scared:
