December 20, 2025, 07:09:18 pm
All Things Mk5
Mk5 General Area
A little Lower
Topic: A little Lower (Read 1555 times)
dazza
Admin
Just look at my post count
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
A little Lower
August 17, 2014, 12:07:05 am »
I would like a mild drop.
I've been reading a lot about lowering springs,shocks and coils.
A lot of people compare them to stock. But how about stock @ 90k
I'm thinking about Koni FSD/Eibach Pro Kit how would this compare to stock @ 90k?
I'd love to bag it notch the frame and lay frame when i pick the kids up from school but wife would sh*t the bed.
Coils sound good but pointless for me as once i find the right height i would probably not change it again.
05 | Tornado Red | DSG
ROH ECHT
-Given: 113
-Receive: 149
K04 PLAY....ZOOM DIS!
Re: A little Lower
Reply #1 on:
August 17, 2014, 07:58:31 am »
For a mild drop you'd want Eibach's Pro-Kit, H&R Sport, or OEM Performance springs for a 1.0" to 1.5" drop.
Add KONI FSD or Bilstein B8 dampers for the ride quality.
K04 PLAY...K04 turbo/S3 INJ. & FMIC/FORGE FMTC, TB hose, & WG actuator/GIAC's H.O. K04 & DSG TUNES/AWE DV/NEUSPEED P-FLO,TURBO OUTLET & TB pipe/AUTOTECH hpfp/BSH Eng.&Trans Mounts/H&R ARB's/Whiteline Performance springs & W.A.L.K./ECS stage-3 BBK/BILSTEIN B8's...ZOOM'DIS...GIAC K04 tune-2007 Volkswagen GTI: 12.823 @ 112.050 MPH__Voting for my Dragtimes link:
http://www.dragtimes.com/Volkswagen-GTI-Timeslip-25700.html?r=1
GrayMK5GTI
Global Moderator
-Given: 125
-Receive: 248
Re: A little Lower
Reply #2 on:
August 17, 2014, 02:25:56 pm »
At 90k miles, you should replace your shock absorbers too. If they aren't leaking already, they will do within 10k miles of having lowering springs fitted
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Re: A little Lower
Reply #3 on:
August 17, 2014, 06:44:35 pm »
Will i see any improvement with KONI FSD and Eibach's Pro-Kit. Apart from the slight drop?
wardy1311
Just Arrived
-Given: 0
-Receive: 0
Re: A little Lower
Reply #4 on:
August 18, 2014, 08:57:14 pm »
The eibach pro kit will give you a 30mm drop and you are able to use standard dampers with them
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Re: A little Lower
Reply #5 on:
August 18, 2014, 09:04:12 pm »
Koni FSD are very well liked, especially when used with the Eibach sport springs. Comments usually revolve around how OEM the ride comfort is but handling is improved dramatically. But coilovers are at an advantage as you can Taylor the ride height perfectly for your needsnow or in the future. A Bilstein B14 may be a few hundred more but for performance and lowering, they'rethe better option long term (in my opinion). H&R are well rated too and offer ultra low kits for those who like to really drop the ride height.
ROH ECHT
-Given: 113
-Receive: 149
Re: A little Lower
Reply #6 on:
August 19, 2014, 02:40:32 am »
Yes, do the dampers when you add the springs. I got about 35k miles(from 25k to 60k miles) extra from the oem dampers when I added my springs, but as said, with 90k miles you should do them at the same time.
mrzed
Taking part
-Given: 3
-Receive: 0
Re: A little Lower
Reply #7 on:
August 19, 2014, 11:36:12 am »
I've just put Eibach springs on mine and the shocks have 100k on them
dazza
Admin
-Given: 90
-Receive: 190
Coding Boffin
My Ride:
Re: A little Lower
Reply #8 on:
August 19, 2014, 03:12:43 pm »
Thanks for your input guys.
The ride is poor now you can feel every bump the wife even mentioned it when we were on the motorway the other day how you can feel the road.
Hopefully the new tyres will make a different. Eagle F1's A2 There are some Chinese tyres on there at the moment.
Im just hope that i wont bottom out on my drive with the Eibach springs. If this was the case how would the FSD's work with stock springs?
All Things Mk5
Mk5 General Area
A little Lower
