Author Topic: MPG on standard ED30  (Read 4638 times)
Offline oak_grun
« on: August 20, 2014, 08:58:10 am »
Hi,
My trusted Bora TDi has gone to car heaven and im am currenlty using the Edition for the commute to work on a daily basis, approx 20 miles each way.
Thing is, i struggle to get even 30mpg - thats sitting at 65mph on the run into work! :driver:
what do the other Edition 30 owners get mpg wise?
Is this the normal mpg i can expect? i though it woudl be more as its mainly motorway driving!
thanks
Offline jimojameso
Re: MPG on standard ED30
« Reply #1 on: August 20, 2014, 09:02:34 am »
I know its a different model but the best my KO3 gti did was 44mpg at that speed. Something sounds amiss there. My KO4 S3 also did 37mpg.  :confused:
2010 Audi TT RS - Sepang Blue - 420BHP, 600NM
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: August 20, 2014, 09:03:36 am »
something not quite right.
needs checking over
Offline oak_grun
« Reply #3 on: August 20, 2014, 10:06:03 am »
its just had a service at Stealth and nothing was flagged up by them.
Could it be the DV that causing it?
« Reply #4 on: August 20, 2014, 10:19:04 am »
Yeah check the DV and pcv.
I hardly ever get over 30 unless I am trying.
Offline oak_grun
« Reply #5 on: August 20, 2014, 10:30:52 am »
will do.  i hear you, thing is im trying and its struggles to get to 30mpg!! :driver:
whats is the best way to check both DV & PCV?
Are they located in the same area in the engine bay?
thanks
Offline oak_grun
« Reply #6 on: August 20, 2014, 11:04:14 am »
Just spoke to mate and he also suggested in could be the MAF?
Anyone had a similar issue with there Edition?
« Reply #7 on: August 20, 2014, 11:06:40 am »
I cant say Ive heard of many failed MAFs on these
« Reply #8 on: August 20, 2014, 11:16:05 am »
Easy way to test the MAF. Unplug it and go for a drive. You will get an engine light which can be cleared with VCDS but if it drives better then it's your MAF.
As Rich says though not heard of a MAF failing ona TFSI.
Offline oak_grun
« Reply #9 on: August 20, 2014, 11:22:29 am »
thing is is drives fine...does sometimes rev a bit hight inbetween gear changes...will try and get it plugged into vcds...would this be able to tell is its is the BV or PCV
« Reply #10 on: August 20, 2014, 11:48:15 am »
No.
Offline oak_grun
« Reply #11 on: August 20, 2014, 11:58:00 am »
whats the general MPG figure fellow Edition30 owners are getting?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #12 on: August 20, 2014, 01:38:13 pm »
To check dv you need to remove it and inspect manually. There's guides on here for it.
PCV is checked by removing oil cap while engine is running. If it splutters your pcv is fine but if it runs as normal it's gone
Offline oak_grun
« Reply #13 on: August 20, 2014, 02:26:25 pm »
Thanks Luke. Will check them out over the weekend!
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #14 on: August 20, 2014, 05:03:08 pm »
I would say 30mpg was about right for an ED30 having had one for nearly 4 years. As soon as you use any kind of acceleration it knocks a chunk out of your mpg straight away , never got more than 34mpg even on 200 mile round trips .
