Author Topic: Central locking motor replacement - part number  (Read 2946 times)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« on: August 24, 2014, 08:36:59 pm »
So the car goes months without needing any work then.....
VCDS is throwing up the error below which looks to be a failing door lock mechanism, i've yet to get a price from VW but don't expect i'll see much change from £200. Looking on ebay there are a couple of new units below £100 but i can't find a Rev K, can i use a new version instead - 1K0959703MSE1 for instance.
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0913
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
   VCID: 387529A94B2DD9DE637-806D
1 Fault Found:
00098 - Rear Left Central Locking (Safe) Motor (V163)
            012 - Electrical Fault in Circuit - Intermittent
« Last Edit: August 24, 2014, 08:43:12 pm by Degudodger »
Re: Door lock mechanism replacement
« Reply #1 on: August 24, 2014, 08:43:42 pm »
Subscribed to this as mine has an intermittent gremelin where, when reaching 15mph when the doors lock the drivers door now and again fails to lock  :confused:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Central locking motor replacement - part number
« Reply #2 on: August 24, 2014, 08:47:26 pm »
Ive (still) got an issue with a damaged can bus wire in the drivers door loom which gets worse when the temperature drops below 5c causing the door mechanism not to unlock from the key fob. I must get round to it before winter.
Offline doylebros
  • -Receive: 310
« Reply #3 on: August 24, 2014, 10:15:03 pm »
In this thread I made comment as to where I found the item the cheapest for replacement.
http://www.mk5golfgti.co.uk/forum/index.php/topic,87875.0.html
I've had these items apart more than I would like to say and the fault is mainly the plastic drive has worn just enough not to reset the dead lock.
Now the the terminals do have issue which are corrected by resoldering but it's mainly the plastic worn.
So no new bits just means you get very good at removing the door skin - no matter how you clean and lubricate it will return!
Offline doylebros
  • -Receive: 310
« Reply #4 on: August 24, 2014, 10:40:25 pm »
   Coding: 0000144
1 Fault Found:
The item you want is 7L0 839 015 D door lock VW part number  price £132.66 inc vat
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=8&grf=083900420&bf=83900&hgug=839&ug=39&parent_id=2350670
The above part number your quoting is for the window controller
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=9&grf=095910420&bf=95915&hgug=959&ug=59&parent_id=2364466
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #5 on: August 24, 2014, 10:56:33 pm »
Me thinks i may have got myself a little confused  :grin:
Offline doylebros
  • -Receive: 310
« Reply #6 on: August 24, 2014, 10:58:14 pm »
Don't we all! :happy2:
