Author Topic: Adding Speed Cameras to RNS 510  (Read 3852 times)
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« on: September 01, 2014, 03:40:08 pm »
Hi guys,
The VW garage updated me from V9 maps to V10 maps by accident (yes, I know.. what?!) and due to this I've lost my speed cameras which were already installed when I bought the car. I've done some searching and am aware the speed cameras are a POI that you add yourself. I found this guide while searching how to do this: http://www.mk5golfgti.co.uk/forum/index.php/topic,2092.0.html
but that guide requires you to own a copy of the map disc; which I do not.
Is there a way of adding them via memory card which I've missed during my searching?
Cheers  :happy2:
Instagram @george_kersh
Re: Adding Speed Cameras to RNS 510
« Reply #1 on: September 01, 2014, 03:54:53 pm »
Your v9 maps would have had the POIs added in, hence lost whilst being upgraded. I know newer firmware/maps (can't remember which) allow you to add as personal POI via memory card. Might depend on your version of the RNS.
Offline Georrge
« Reply #2 on: September 01, 2014, 03:58:35 pm »
Ah that would make sense then. It's frustrating as I never asked them to update my maps  :sad1:
I found a .db3 file off gpsunderground and it has instructions to add from memory card, but I've just come back from outside because I'm getting the message 'SD Card Error'. I have absolutely no idea why I'm getting this error, this is the same memory card I've used in the unit for the past year, and I literally just copied the .db3 file to it 5 minutes a go, so the card itself is working fine.
Why is nothing straight forward  :signLOL:
« Reply #3 on: September 01, 2014, 04:06:35 pm »
IIRC the firmware have to be okay for you to add it from memory card. Have a quick look on my-gti and it looks like only the latest firmware allows you to do this.
Offline Georrge
« Reply #4 on: September 01, 2014, 04:09:58 pm »
That would make perfect sense as to why the speed cameras were originally added from an altered V9 maps, because my firmware is 0900 as it's a version B unit. Looks like VW are going to have to dig deep to sort this out for me, as I never requested this "upgrade"  :signLOL:
Cheers for your help!  :smiley:
Offline DDM
« Reply #5 on: September 01, 2014, 05:04:28 pm »
I just recently had a rns fitted by Viking, that came fully loaded with everything, send him a pm mate.
Offline Georrge
« Reply #6 on: September 01, 2014, 11:47:17 pm »
I'll do that right away, cheers buddy!
