Author Topic: Dans grey MK5 GTI. Prepping for VagTuner  (Read 301524 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Dans grey MK5 GTI hybrid k03. made a whoopsie
« Reply #480 on: March 10, 2016, 11:11:55 pm »
Excellent write up Dan  :happy2:
Don't like the look of that plug though :surprised: glad it's not damaged anything.  :smiley:
Offline alex55
« Reply #481 on: March 11, 2016, 11:35:55 pm »
enjoyed the read
dansmith180
« Reply #482 on: March 13, 2016, 09:54:37 am »
So after the spark plug issue and suspected under fuelling I changed the fuel filter and upgraded the LPFP to one of these
http://www.awesomegti.com/car/vw/golfmk5/deatschwerks-dw65v-high-flow-fuel-pump-90769
Then yesterday she went on the dyno for testing to log all parameters and see if anything is wrong.
So glad I bothered to clean it the Friday evening before as I love how the wheels and brakes look when spinning  :innocent:. First time I've ever uploaded to YouTube and seems that it dropped the quality a bit which is annoying.
After half a dozen or so runs it seems all the big important things are running fine and fuelling is perfect now. However it sometimes holds back up top as the ECU is getting a bad reading from one of the sensors, which is on its way out, but unfortunately the ECU won't tell us which sensor is giving the bad reading so basically I need to keep driving and regularly check for fault codes until something comes up. Not great but not bad however at least now I can now go out and enjoy the car again even if its down about 20bhp.
« Last Edit: March 13, 2016, 10:16:46 am by dansmith180 »
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #483 on: March 13, 2016, 02:33:38 pm »
Hope you find the culprit Dan, must be a bit gutting after everything you've invested in the car.
The brakes do look a bit special mate. You did the right thing getting them refinished in red!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pdtvem1vbte61hb055iqgs3vbr&/topic,19740.0.html
« Reply #484 on: March 13, 2016, 03:08:30 pm »
are you running the stock IC?
dansmith180
« Reply #485 on: March 13, 2016, 04:12:45 pm »
Nah that would probably melt  :signLOL:
Got the Forge OEM replacement one after the Twintercooler didnt fit at all.
« Reply #486 on: March 13, 2016, 04:35:59 pm »
Have you logged fuel rail pressure? Are you on LOBA? RS4 FRV?
dansmith180
« Reply #487 on: March 13, 2016, 05:11:04 pm »
Cheers mate yeah its quite frustrating really
I'm eyeing up a BWJ engine with 41K on it at the moment so might be an engine swap coming soon  :evilgrin:
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #488 on: March 13, 2016, 05:13:39 pm »
With the stronger internals in mind??
dansmith180
« Reply #489 on: March 13, 2016, 05:34:20 pm »
Loba pump standard FPRV
Everything possible was logged and air/ boost/ fuel/ temps ect.. Are all perfect. For some reason the ECU thinks something isn't right but won't tell us what. BWJ lump is on the cards as I CBA with this engine anymore.
« Reply #490 on: March 13, 2016, 05:39:34 pm »
Fuelling might be ok... but thats not to say the rail pressure it keeping up. It wont throw a fault code, but you will feel it pulling the power. Might be worth throwing on an RS4 valve. Start with the cheap things first.
dansmith180
« Reply #491 on: March 13, 2016, 05:50:55 pm »
Stronger internals, generally an improved engine, 72k less miles, 3 years newer etc....
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #492 on: March 13, 2016, 05:58:56 pm »
Makes sense if you can get it done at the right price. Would you stick with the hybrid k03 or go for a tte420 though...?
dansmith180
« Reply #493 on: March 13, 2016, 06:33:01 pm »
Will most likely just keep stock K04 as this engine comes whole and has low miles.
Went for a drive and got this now   :indifferent:
Me and this car aren't friends anymore.
« Reply #494 on: March 13, 2016, 06:37:08 pm »
Dont panic.... clear them.... go for another drive... recheck!
