Author Topic: Oil leak... pic inside :(  (Read 12283 times)
Offline Broomy
  • -Given: 18
« on: September 17, 2014, 08:46:18 pm »
Was giving the car a check over this evening for my MOT on Saturday & noticed a bit of oil on the under tray.
Whipped it off to see this.
Just in from the screws that hold the under tray on the n/s.
I did some searching before posting & it seems to be the inter cooler pipe?
Can anyone confirm or advise what could be leaking? No patches on the drive but would rather get it sorted.
It does use some oil but I thought the mk5 GTI did use a bit? I didn't think it was overly excessive. 1tr per 2/3 mths.
Cheers.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Oil leak... pic inside :(
« Reply #1 on: September 17, 2014, 08:51:56 pm »
Very common leak - mine does it. You can buy a new washer for pennies at a dealer  :happy2:
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: September 17, 2014, 08:53:28 pm »
Mine had the same thing but the pipe looked like it was seated OK. Is this oil from vaporised oil that is re-entered into the intake system via the PCV? Can not work out how oil ends up in the inter cooler intake?!
Offline Broomy
  • -Given: 18
« Reply #3 on: September 17, 2014, 09:00:22 pm »
Thanks for the replies.
Phew that's a relief, haven't a clue how it gets there  , will have to get it sorted though castrol edge isn't cheap.
Can that just be unclipped & seal replaced on the drive?
« Last Edit: September 17, 2014, 09:35:35 pm by Broomy »
Offline MJGib
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,85702
« Reply #4 on: September 18, 2014, 08:29:39 am »
I'd check your intercooler make sure it's not filled up with oil that's a lot of oil to come out a intercooler pipe there should only be a small amount
MK5 Golf GTI: K04 converted stage 2+ (I don't own this car no more)
Insta - gibs94_
Offline xjay1337
  • -Receive: 377
« Reply #5 on: September 18, 2014, 09:20:48 am »
You need to replace the hose, C clip and o ring seal (on both ends).
It's approx £65 from VW.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #6 on: September 18, 2014, 10:06:55 am »
Or you can cut the bayonet fitting off the pipe, and buy an adaptor from somewhere like Creation Motorsport on eBay for £20 delivered and save yourself a fair few quid, just needs a jubilee or T-bolt clamp, and the o-ring and c-clip which are a couple of quid tops on their own  :happy2:
Offline Scrubadub
  • Soon to be "bagged"
« Reply #7 on: September 18, 2014, 01:12:58 pm »
That joint is about to blow! I bet the lugs are worn on the hose, as above get a new hose and seals or adaptor. I went the adapter route on eBay search boost bayonet
Fun bags
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #8 on: September 18, 2014, 01:44:50 pm »
+1
I had the same problem a few months back.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #9 on: September 18, 2014, 05:16:12 pm »
In definite need of proper fitting again...you are losing boost. The oil is normal but not if it appears to be an excessive amount. It should only lightly coat things if at all. Also, if oil is excessive there, you may have a cracked EVAP portal in the valve cover allowing oil to be sucked into the EVAP line that goes into the turbo inlet...but you will notice excessive oil usage and smoky exhaust at high revs and under boost. See my post if this may be the case:
http://www.mk5golfgti.co.uk/forum/index.php/topic,88806.msg900231.html#msg900231
Offline Broomy
  • -Given: 18
« Reply #10 on: September 18, 2014, 10:28:18 pm »
I wouldn't know how to start & butcher bits, I'll order the replacement parts.
Intercooler hose? X2
Intercooler c clip x2
O ring seals x 2
Cheers for the input, appreciated.
Offline xjay1337
  • -Receive: 377
« Reply #11 on: September 18, 2014, 10:36:03 pm »
One intercooler hose.....
Give me your email and I'll forward you etka info tomorrow..
Offline Broomy
  • -Given: 18
« Reply #12 on: September 18, 2014, 10:58:15 pm »
Cheers buddy, PM enroute.
Offline Broomy
  • -Given: 18
« Reply #13 on: September 19, 2014, 12:57:32 am »
Is this likely to be an MOT failure? I need to reschedule before 12 tomorrow to avoid losing out on the fee.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #14 on: September 19, 2014, 07:37:32 am »
Clean it all up as best you can and it should be ok
