Author Topic: Two annoying noises inside the cabin  (Read 1296 times)
Offline Bennz
« on: September 18, 2014, 02:42:56 am »
I have two noises which I have been trying to get rid off
1- the rattle from middle of roof inside the cabin. I am not sure if it's because of the wires to the back roof lights ? Has anyone experienced this ?
2- wind noise from the driver door when on motorway , I checked the seals and seem to be okay. Any suggestion?
Offline AndyBrown
Re: Two annoying noises inside the cabin
« Reply #1 on: September 18, 2014, 05:59:30 am »
I had an annoying noise in the cabin before,  turned out it was my girlfriend.
Offline jbenekeorr
« Reply #2 on: September 18, 2014, 07:25:29 am »
  :grin:
I have some wind noise from what appears to be the passenger side mirror when at certain speeds, so yours could be the drivers mirror. I'm sure I've read before that a lot of them suffer from this, it's like a very quiet whistling which you would hear if the radio wasn't on.
Offline Bennz
« Reply #3 on: September 18, 2014, 10:46:02 am »
The noise actually comes from the top corner of the driver door.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #4 on: September 18, 2014, 11:49:55 am »
 :signLOL:
Maybe your door needs re-hung, sometimes with leaning on the door, or when passengers getting in and out, lean on the door i suspect it drops a bit.
If you look at the line from outside the car, just to see if everything lines up ok...
I seen a guy adjust the catch that the door clicks into adjust that, and it fixed a simliar problem....
Worth a try !
Silver is the way !
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #5 on: September 18, 2014, 02:03:43 pm »
Mine has the same problem!
High-pitched wind noise when over 50mph.
I've checked the alignment of the door and its seals - but everything looks good to me... Maybe I've just got a bad eye  :sad1:
Offline GTIdanman
« Reply #6 on: September 18, 2014, 07:47:05 pm »
my driver side wing mirror also makes a whistling noise at around 30 to 40 mph. bit annoying but nothing major. :smiley:
Offline Bennz
« Reply #7 on: September 18, 2014, 09:09:08 pm »
What about the rattling noise in the ceiling from inside ? Has anyone else have it ? When I press the ceiling in the middle while driving the noise stop . But no clue to to permanently stop it
