Author Topic: Please check the pressure in your saver spare tyre...  (Read 2816 times)
Offline bacillus
  • -Receive: 451
« on: September 21, 2014, 04:30:16 pm »
Most folk will rarely, if ever, need to use their spare tyre.
With the months, if not years of "neglect", the pressure could drop to an unsafe level for use as a spare.
So please check its pressure and inflate as necessary. The stated inflation pressure is 60psi.
I checked mine today after neglecting to do so for many months and found the pressure to have dropped to 39psi.  :scared:
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: Please check the pressure in your saver spare tyre...
« Reply #1 on: September 21, 2014, 04:33:50 pm »
good shout, not even taken mine out of the boot since i brought the car
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #2 on: September 21, 2014, 04:53:11 pm »
That's a good shout! Must check mine...
I'm in the process of getting rid of the space saver altogether though! Have sourced a spare Pescara, & have bought the foam trims to raise the boot floor.
Would like to junk the VW jack too, but not sure of a compact alternative!
Edition 30 - no. 1387
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #3 on: September 22, 2014, 04:51:26 pm »
mines in the garage as it wont go over the BBK, so cant carry a spare space saver
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=44obbsm4a3d0qsdjnv5cosatbh&/topic,19740.0.html
« Reply #4 on: September 22, 2014, 04:58:55 pm »
Swap it onto the back? That's what I'll have to do.
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
« Reply #5 on: September 22, 2014, 05:00:26 pm »
can of tyre gunk and enjoy the 0.0015 of mpg you get with the weight saving  :evilgrin:
Tornado red ed30 #0728
« Reply #6 on: September 22, 2014, 06:06:57 pm »
I'm sure I read in the manual that you're only meant to use the spacesaver on the rear axle and not the front? So if you have a puncture on a front tyre, you swap it with the back and stick the spacesaver on the back. Also these are rated for only certain distances (can't recall - was it 50 miles?) after which they should be replaced.
