Author Topic: Key N/W  (Read 1355 times)
Offline Markweir12
Key N/W
« on: October 06, 2014, 01:00:23 pm »
Hi guys,
went home on lunch and key unlocked car fine, get back to work and now it wont lock car?
won't make any noises when pressing either button.
Light flashes on key fob on every button.
Offline bacillus
  • -Receive: 451
Re: Key N/W
« Reply #1 on: October 06, 2014, 01:21:04 pm »
Does the locking work with your other key/fob?
Offline Markweir12
Re: Key N/W
« Reply #2 on: October 06, 2014, 01:46:29 pm »
I only have one fob.
Locks the car fine with the blade just not the buttons
Offline xjay1337
  • -Receive: 377
Re: Key N/W
« Reply #3 on: October 06, 2014, 01:57:19 pm »
Possibly need the central locking recoded. Although I'd scan with VCDS to ensure the wireless thingy hasn't failed.. also check the battery.
P.S your Boost gauge is on da way :)
Offline Markweir12
Re: Key N/W
« Reply #4 on: October 06, 2014, 02:25:02 pm »
Key is sending a signal which suggests battery is fine.
Will get my mate to check on VCD's
Offline Markweir12
Re: Key N/W
« Reply #5 on: October 06, 2014, 09:34:40 pm »
Any other ideas gents?
Would it need to be recoded at stealers? As I don't have a spare
Offline OSB
  • -Given: 32
Re: Key N/W
« Reply #6 on: October 07, 2014, 07:33:48 am »
Try changing the key fob battery. The LED can flash but there is not enough power to send sufficient signal to operate the car electronics.
Offline Markweir12
Re: Key N/W
« Reply #7 on: October 07, 2014, 07:44:42 am »
Will try that today then, do you just unscrew it then pull it apart?
Offline OSB
  • -Given: 32
Re: Key N/W
« Reply #8 on: October 07, 2014, 07:49:07 am »
Have  a look on YouTube (how to replace key fob battery vw Golf Mk5) - several good guides on there. Bit fiddly first time but no real problem.
Just off to work - no time to post one now! I'll look later on.
BTW worked for me! Battery is a button cell 2032 if I remember correctly.
Offline OSB
  • -Given: 32
Re: Key N/W
« Reply #9 on: October 07, 2014, 07:51:58 am »
Found it!
&app=desktop
Offline Markweir12
Re: Key N/W
« Reply #10 on: October 07, 2014, 08:24:01 am »
no joy :(
Lights flash on key, sends a signal to my work receiver just won't unlock my damned car aha!
Offline Markweir12
Re: Key N/W
« Reply #11 on: October 07, 2014, 01:03:20 pm »
Key now works again ... strange.
Offline warby
Re: Key N/W
« Reply #12 on: October 08, 2014, 07:59:23 am »
If you want, I'll bring the laptop out at the weekend and stick it on quickly :)
Offline Markweir12
Re: Key N/W
« Reply #13 on: October 08, 2014, 08:22:00 am »
Ye man, I should be about on Friday + Saturday.
Will try and get another key sorted at some point too
