Author Topic: Steering Rack Noise and Clunking Over Bumps. Help Appreciated. Thanks  (Read 4222 times)
Offline monk180
Hi Folks,
On my golf there is a noise from the steering rack.
Best heard, when the engine is off, with key on position 1 so the steering lock is off.
When you "Quickly Waggle" the wheel left and right slightly, is feels there is free play and also a clunk when it feels the free play is take up in both directions. I guess it must be free play cause the power steering is off, and tyres cannot move when doing this.
Also a loud clunk from the front / suspension when going over bumps - not speed humps, but if the road patters, like pot hols / low sunken drain covers ect.
Your help would be much appreciated.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Steering Rack Noise and Clunking Over Bumps. Help Appreciated. Thanks
« Reply #1 on: October 11, 2014, 10:15:14 pm »
Most likley the rack bushes (about £40 from VW) but could also be the dreaded inner track rod ends (like i had) needing a new rack.
Offline monk180
« Reply #2 on: October 11, 2014, 10:21:33 pm »
Thanks for the reply.
It has had this issue before, it came back from a service fixed, then is started doing it again gradually getting worse.
That suggest something has worked itself loose?  Yes track rods end been done twice!
Offline monk180
« Reply #3 on: October 11, 2014, 10:23:31 pm »
So what I meant is that it came back fixed without any new parts.
Then it started coming back, slowly worse.
So this tells me, something has worked loose rather than a part failing, if it was serviced and fixed with no parts replaced.
Offline doylebros
  • -Receive: 310
« Reply #4 on: October 11, 2014, 10:26:50 pm »
Possibly they may of just sprayed certain areas with a lub spray which solved the issue short term?
Offline rosscoe63
« Reply #5 on: October 12, 2014, 05:04:06 pm »
I've got the clunk from 'pattering' and its in for a check this weekend......will let you know how I get on
Offline marko
« Reply #6 on: October 12, 2014, 07:50:31 pm »
Front subframe bolts loose??
There's a kit available if this is the case
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline rosscoe63
« Reply #7 on: October 12, 2014, 10:31:25 pm »
is this a common thing matey??
Offline marko
« Reply #8 on: October 12, 2014, 10:52:27 pm »
The fact that a kit is available would suggest that..
Hasn't happened on mine but i replaced the bolts anyway
