I'm gagging for justification to put one of those carbon inlets somewhere. I wonder if I could duct feed extra to the side filter box on the Forge Twintake.
I,m in the process of this at the moment.. I'm modifying the inlet duct around the headlight and directing air to it from a modified lower grille
.Not that it need's it mind....
....Aahaaa!
Very interesting!
So as I understand it, you're modifying the Twintake's 'headlight area' duct and then directing air to it via a hose(?) from a modified lower grille?
And when you say "modified lower grille" do you mean foglight grill or lower full frontal grill below the numberplate?
ITG's tech-head Andy tells me that the best place of all to feed from below is in the lower centre grill rather than the foglight grill where air has begun to slip sideways unless you have a NACA duct to help capture it.
I'd be very interested to learn what you've done when completed, as I expect others would too.
![happy2 :happy2:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/happy2.gif)
