Author Topic: RCD510 firmware updaing?  (Read 2242 times)
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« on: October 30, 2014, 08:28:54 pm »
Hi
just after a bit of advise, ive just changed to and RCD510. how do i check what firmware its running?
any tips on upgrading it?
« Last Edit: October 30, 2014, 10:53:23 pm by DamoP »
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=qpfhp4pittc1mc80levivapuo1&/topic,90967.msg917089.html#msg917089
Re: RCD510
« Reply #1 on: October 30, 2014, 08:40:52 pm »
Hold down the settings button. Menu should come up with version info.
05 | Tornado Red | DSG
Offline DamoP
  • -Receive: 115
Re: RCD510
« Reply #2 on: October 30, 2014, 08:46:03 pm »
ill give that a go after work. is it simple to update?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: RCD510
« Reply #3 on: October 30, 2014, 08:54:32 pm »
No idea mate. The guy i bought mine off said it was running the latest firmware. If it not broke and all that.
Offline mk4gti-t
  • -Given: 61
Re: RCD510
« Reply #4 on: October 30, 2014, 10:22:06 pm »
I tried holding down the set up button but it just went into radio test mode or something like that.....
Offline DamoP
  • -Receive: 115
Re: RCD510
« Reply #5 on: October 31, 2014, 04:42:46 am »
mine has just done the same, it comes up am/fm
Offline DamoP
  • -Receive: 115
Re: RCD510
« Reply #6 on: October 31, 2014, 05:49:16 am »
Offline john87
  • -Receive: 53
Re: RCD510 firmware updaing?
« Reply #7 on: October 31, 2014, 09:59:13 am »
Hold it down even longer and it should go into a second menu  :happy2:
Offline Schorly
« Reply #8 on: October 31, 2014, 03:04:05 pm »
Once you are at the AM FM screen there should be another field, which when selected gives you the information you are after. If not your firmware does not allow you to see this information. I had the same problem, but after updating my RNS510 to the latest firmware I found the selector for the system information was available. So I think you need to upgrade your firmware, since newer versions give you this function. Upgrading is easy. The trick is to get the DVD with the new firmware working in the first place.
Offline DamoP
  • -Receive: 115
« Reply #9 on: November 02, 2014, 07:07:24 am »
can you pm me where you got it from. as i cant get past the am/fm screen
