Author Topic: DSG Clunk after reset using VCDS  (Read 4232 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« on: November 07, 2014, 09:17:07 am »
Hi all.
I done a DSG Reset on my TDI last night, car drives smoother, but when I am stationary and I select from N to D,I get a small clunk noise. and sometimes i see the gear number say 2 and then it quickly changes to 1.
I havent tested it this morning but will do tonight.
If i am driving and go into N and then into D, it doesnt do it. Only stationary.
Any ideas?
Also had the DSG service done yesterday too, didnt do it before the reset.
Redemption
Re: DSG Clunk after reset using VCDS
« Reply #1 on: November 07, 2014, 10:08:40 am »
I'd drive it for a while and see if the 'clunk' sorts itself out. It may just need time adapting. If it remains the same then take it back to where you had it serviced and see what they have to say.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: November 07, 2014, 10:14:54 am »
cheers bud. Im thinking of taking it for a long drive tonight mixture of town and dual carriage ways.
Should I drive it in M mode for it to adapt?
Redemption
« Reply #3 on: November 07, 2014, 10:20:43 am »
Won't hurt to use M mode but I'd just use D to start with and see how it goes.
Offline akbarirfan
  • -Given: 81
« Reply #4 on: November 07, 2014, 12:32:49 pm »
I had the same, went after 2-3 normal work commutes  :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: November 07, 2014, 12:34:10 pm »
Thanks mate. Was it after a DSG Reset it happened to you too?
Offline akbarirfan
  • -Given: 81
« Reply #6 on: November 07, 2014, 12:40:13 pm »
Yes sir  :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: November 07, 2014, 12:42:17 pm »
I get a clunk when selecting D/R thought this was normal??
05 | Tornado Red | DSG
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #8 on: November 07, 2014, 01:12:05 pm »
No clunks on mine  :happy2:
Offline grumpy
« Reply #9 on: November 07, 2014, 11:12:30 pm »
Hi mate,
Maybe check your subframe it nice and tight. The reason I suggest this is because I too had a little dsg clunk. I had a friend install the subframe Audi bolt/spacer mod then noticed the gear selection clunk had gone.
Thanks.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: November 08, 2014, 02:49:22 pm »
Just had a try today, noticed it only happens when the car is cold. Once warmed up it never clunks. Is this normal?
Redemption
« Reply #11 on: November 08, 2014, 03:04:20 pm »
Both cars I've had with DSG boxes were better when warmed up. Get occasional clicks from mine when it's cold that go when it's warm so I'd say yours is ok.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: November 08, 2014, 06:45:50 pm »
Yeah it seems ok now,took it up the M1 on a 150 mile journey and drives very nice! Thanks for all the help everyone.
downsideup
« Reply #13 on: November 10, 2014, 04:13:10 pm »
I had same issue when I reset mine, I thought I had screwed it, but after a few days it disappeared.
