Author Topic: Idle hunting  (Read 1956 times)
Offline Pikey Motorsports
Idle hunting
« on: November 10, 2014, 08:11:57 am »
Ive always had abit of idle hunting when cold with the rs4 injectors but yesterday its staying permanent and afr gauge is showing rich on idle.. Car sometimes hesitates alittle bellow 2,000rpm but only sometimes and very slightly
Car is fine on wot and so are afrs, im thinking some kind of vac leak or sensor problem, flapper motor?
Anyone got any ideals
P.s had a new catback the day before.. Was fine that night when i took it out to test and then the next day i had this issue. I dont think its related to the exhaust though
« Last Edit: November 10, 2014, 09:12:37 am by Pikey Motorsports »
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Re: Idle hunting
« Reply #1 on: November 10, 2014, 03:30:23 pm »
Any ideals anyone?
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline vRSAlex
  • -Receive: 253
Re: Idle hunting
« Reply #2 on: November 10, 2014, 04:51:30 pm »
Get it smoke tested to eliminate all leaks.
Follow AKS tuning on Facebook
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
Re: Idle hunting
« Reply #3 on: November 10, 2014, 05:25:59 pm »
alex do you have a guide on were to smoketest the 2.0tfsi?
do you have to block certiain pcv like the 1.8t?
Tornado red ed30 #0728
Offline vRSAlex
  • -Receive: 253
Re: Idle hunting
« Reply #4 on: November 10, 2014, 06:30:02 pm »
I just pop the air filter off and go through the intake pipe.  It doesn't run that much pressure so doesn't always show minor leaks.  Nothing needs blanking off.
Re: Idle hunting
« Reply #5 on: November 10, 2014, 06:53:52 pm »
Ok alex cheers.. I just plugged it into vagcom and got a camshaft timing adjustment fault
and then found this
Also found a fault for leak in air intake system
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Re: Idle hunting
« Reply #6 on: November 10, 2014, 08:25:37 pm »
Its the n205 sensor right alex? How do i remove it dude
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline vRSAlex
  • -Receive: 253
Re: Idle hunting
« Reply #7 on: November 10, 2014, 10:44:20 pm »
That's been broken and glued up before. It just has two screws. T-15 or T-20.  Have a rag as some oil will come out if it. Around £100 iirc.
Re: Idle hunting
« Reply #8 on: November 10, 2014, 11:41:13 pm »
I thought it looked like it had been glued.. Hopefully will fix the problem but not sure as also has the leak in air intake fault.. Either way it needs replacing and im sure its not helping the prob
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
