Author Topic: Golf Mk5 Gti Retrofit OEM Xenon Headlights  (Read 11122 times)
Offline K9
  • VW LifeStyle
« on: November 10, 2014, 07:09:33 pm »
hey guys, i'm sure this have been up alot but my question is just that i bought a set of oem xenon headlight units, came without ballasters, igniters, and bulbs.
So now i'm buying 2x oem d2s ballasters, 2x oem ignitors, kufatec adapters and i need a housing repair set for my right side housing as they are broken. Got the units for around 60£!
They came with high beam bulbs as i checked they where made in germany and philps h7 bulbs. When installing do i need to modify to get the normal halogen highbeam to work or just connect the wires to standard connector when removing oem halogen housings? would like to have the bi-xenon but not sure if my comfort box is the correct one  :sad1:
is this all what i need?
2x oem ballasters
2x oem igniters ( are they teh same for right side housing and left side?? )
1x kufatec pin adapter
2x oem or some aftermarket D2S bulbs in 4300k
thanks for your answers and any helping links and vids or pics are accepted  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Golf Mk5 Gti Retrofit OEM Xenon Headlights
« Reply #1 on: November 10, 2014, 07:23:59 pm »
2x oem ballasters
High beam halogen will work automatically if you don't enable the bi-xenon function, you don't need to run any other wires, all in the kufatec adapters
This should help, complete breakdown of the unit
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1731&ein=2008&f=625&hauptgr=1234567890&hg=9&grf=094120420&bf=94120&hgug=941&ug=41&parent_id=2869564
Repair tabs are highlighted and you can pick up the screws etc you need for the ballasts, don't forget the retaining ring for the bulb and igniter  :happy2:
Offline K9
  • VW LifeStyle
« Reply #2 on: November 10, 2014, 07:27:07 pm »
2x oem ballasters
part numbers for the "rings" and any prices? buying from a member here the ballasters and one igniters so i will need to hunt for one more :)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: November 10, 2014, 07:30:28 pm »
Part numbers are on the link mate, just click the item number  :wink:
Ring your VW parts dept with numbers and you'll get a price  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: November 10, 2014, 07:31:30 pm »
I posted in your wanted thread a link to German ebay for the igniters  :happy2:
Offline K9
  • VW LifeStyle
« Reply #5 on: November 10, 2014, 07:40:58 pm »
ye i noticed now  :happy2: so they are the same for right and left side?
this is a pic from the d2s inside, missing anything exept the bulb?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #6 on: November 10, 2014, 07:50:38 pm »
Yes the same left or right. You have the retaining ring so yes just missing the bulbs and igniters  :happy2:
Offline K9
  • VW LifeStyle
« Reply #7 on: November 10, 2014, 07:55:08 pm »
what aftermarket d2s bulb will also work fine? cant afford the oem d2s work dealer :O
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #8 on: November 10, 2014, 08:01:48 pm »
http://www.ebay.co.uk/itm/300999156867?_trksid=p2060778.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I am getting these soon!  :happy2:
« Last Edit: November 10, 2014, 08:06:07 pm by StuF »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #9 on: November 10, 2014, 08:03:38 pm »
Osram nightbreakers get good reviews  :happy2:
Offline K9
  • VW LifeStyle
« Reply #10 on: November 10, 2014, 08:10:18 pm »
will keep in-mind  :driver:
to run bi-xenon with shutter then do it only work with highline Comfort module? how can i check what i got? i have vcds genuine ross-tech
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #11 on: November 10, 2014, 08:14:07 pm »
If you have a GTI more than likely you have a highline CECM. Scan and post up the part nunber for module 9
Offline K9
  • VW LifeStyle
« Reply #12 on: November 10, 2014, 08:17:03 pm »
ok will do that tomorrow after work  :jumpmove:
let me know if you know someone who selling a repair housing kit for Right housing and 1 igniter for checper the ebay price  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #13 on: November 10, 2014, 08:19:55 pm »
Which tabs are broken on the right light? I might have a spare in the shed  :smiley:
Offline K9
  • VW LifeStyle
« Reply #14 on: November 10, 2014, 08:29:09 pm »
all 3  :scared: :confused:
