December 23, 2025, 12:41:41 am
All Things Mk5
Sat Nav and Car Audio
mfd2 aux point
Topic: mfd2 aux point (Read 4437 times)
Whitt_tdi
Always Involved
-Given: 2
-Receive: 1
mfd2 aux point
November 12, 2014, 05:52:25 pm »
Hi all. Iv looked through a few threads but can't seem to find what I want. Iv just got a mfd2 sat nav for my golf and I want an aux point putting in but I'd like to have the aux point next to the tc and winter switch in the console so it looks more like a oem install? Is this possible or are there any other options? I have an ipod but also a samsung s5 so want something I can use both with or maybe plug play and charge the ipod?
Horatio
Won't Shut up.
-Given: 23
-Receive: 39
Re: mfd2 aux point
Reply #1 on:
November 12, 2014, 06:05:15 pm »
The aux input is fairly pants, I thinks it's a phono jack, the mdi kit enables either usb or iphone connections. I might be wrong. Theresa's mdi kit in the for sale section
Whitt_tdi
Always Involved
-Given: 2
-Receive: 1
Re: mfd2 aux point
Reply #2 on:
November 12, 2014, 06:18:35 pm »
Mdi kits don't work on the mfd2 that's why I just wanted a oem aux point for my phone really
Shoduchi
Just look at my post count
-Given: 220
-Receive: 430
My Ride:
Re: mfd2 aux point
Reply #3 on:
November 12, 2014, 06:26:56 pm »
You can get one of those from ebay or aliexpress.com.
Silver Reflex Mk5 Golf GT Sport
.:R-Line
1.9 TDI 105@171PS 5 Doors
Candy White Mk5 Golf GTI Edition 30 DSG 230@409PS 3 Doors
Whitt_tdi
Always Involved
-Given: 2
-Receive: 1
Re: mfd2 aux point
Reply #4 on:
November 12, 2014, 06:29:32 pm »
Iv seen one on ebay but it states in the description it's for the rns 510 and I don't know if they are the same connection or not
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Re: mfd2 aux point
Reply #5 on:
November 12, 2014, 06:34:38 pm »
It's not the same, you'd have to change at least one wire, because they have different pin placements.
.:R-Line
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Re: mfd2 aux point
Reply #6 on:
November 12, 2014, 06:42:00 pm »
This kit will work and probably has instructions explaining where you should place each wire depending on the headunit you have:
http://www.ebay.co.uk/itm/221588394023
Just follow this pinout image:
Just not sure about the rear plug. I know it has to be a 18-pin connector and that item from the ebay doesn't have this:
You can always get the correct 18-pin connector and fit in the ebay aux-in.
Last Edit: November 12, 2014, 06:48:07 pm by Shoduchi
.:R-Line
Whitt_tdi
Always Involved
-Given: 2
-Receive: 1
Re: mfd2 aux point
Reply #7 on:
November 12, 2014, 06:54:21 pm »
That's the one iv seen just wasn't sure if it would fit the mfd2
Shoduchi
-Given: 220
-Receive: 430
My Ride:
Re: mfd2 aux point
Reply #8 on:
November 12, 2014, 06:59:47 pm »
I think you might need to fit the 18-pin plug I put above. If you get the Aux-in adapter that you can found it on electronic stores, I'm sure you'll be able to retrofit the Aux-in like you want to.
Aux-in adapter:
http://www.ebay.co.uk/itm/360549569833
Last Edit: November 12, 2014, 07:01:37 pm by Shoduchi
.:R-Line
Whitt_tdi
Always Involved
-Given: 2
-Receive: 1
Re: mfd2 aux point
Reply #9 on:
November 12, 2014, 08:33:59 pm »
OK cool. Thanks for your help. I'll use that for now and then see if I can retro fit one in some how
All Things Mk5
mfd2 aux point
