December 19, 2025, 06:28:59 pm
All Things Mk5
Mk5 General Area
Coolant - How full?
Topic: Coolant - How full? (Read 2527 times)
Frenzy
Won't Shut up.
-Given: 62
-Receive: 29
Coolant - How full?
November 15, 2014, 04:20:40 pm »
How full is your reservoir with coolant?
I ask because mine currently sits at the black line above the black line which says min (so in other words min line plus about an inch and a half) and i don't know whether it should get a top up to be on the safe side.
I'm guessing that actually having this much coolant above the min line equates to quite a lot of normal driving miles.
GrayMK5GTI
Global Moderator
Just look at my post count
-Given: 125
-Receive: 248
Re: Coolant - How full?
Reply #1 on:
November 15, 2014, 04:23:45 pm »
I kept mine at the top of those lines but Statllers filled it up to the middle line in the tank.
howie1987
Won't Shut up.
-Given: 92
-Receive: 20
Reply #2 on:
November 15, 2014, 06:56:25 pm »
I had mine done recently by audi and its above the lines.
dansmith180
Reply #3 on:
November 15, 2014, 09:45:35 pm »
I always have it half way between the lines or higher
vRSAlex
Admin
-Given: 39
-Receive: 253
My Ride:
Reply #4 on:
November 16, 2014, 09:28:35 am »
Min when cold, max when hot.
Build Thread
www.akstuning.co.uk
- info@akstuning.com - 01234 822324
Follow AKS tuning on
Facebook
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #5 on:
November 16, 2014, 09:41:50 am »
I was always advised to fill it to just above minimum as it allows for an expansion of the fluid plus allows the pressure inside the system to remain stable. Too little space in the previous means not enough space for the build up of pressure when at high temperatures.
Frenzy
Won't Shut up.
-Given: 62
-Receive: 29
Reply #6 on:
November 16, 2014, 05:30:07 pm »
Cheers for the replies fellas and thanks for the explanation th3_f15t.
So my coolant level is absolutely fine which means the 'STOP check coolant levels' message i get from the dash in cold weather is being caused by a dodgy sensor...? Anyone else had this?
cheers
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #7 on:
November 16, 2014, 05:55:39 pm »
Yeah, most likely a faulty sensor. A fault scan of the ECU will tell you, but nothing wrong with removing the sensor, cleaning the metal prongs and checking the wiring for any obvious damage. Cheapest solution first...
All Things Mk5
Mk5 General Area
Coolant - How full?
