Author Topic: Cam adjuster noise  (Read 2320 times)
Offline Carl123
Cam adjuster noise
« on: November 17, 2014, 10:43:32 pm »
Right as title states had my cam chain and tensioner replaced not long ago with cambelt and water pump now I get my eml light on with code p000a slow response also I have a vid of how it sounds from cold start up until it's warm really bugging me help would be nice please
http://s1278.photobucket.com/user/Carl_Richard_Beale/media/473D41CE-8BB0-46BD-A3C3-506CD9340790_zpswxmec023.mp4.html
« Last Edit: November 17, 2014, 10:45:47 pm by Carl123 »
Offline Carl123
Re: Cam adjuster noise
« Reply #1 on: November 18, 2014, 08:44:47 am »
Morning bump any1 please
Offline Carl123
« Reply #2 on: November 21, 2014, 08:32:27 pm »
Has no1 had this issue before??
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bet7plngljrt8lgr6mjcscv42c&/topic,90967.msg917089.html#msg917089
« Reply #3 on: November 21, 2014, 08:49:13 pm »
Didn't you change the cam adjustor sensor? And it was running well?
05 | Tornado Red | DSG
Offline Carl123
« Reply #4 on: November 21, 2014, 11:01:34 pm »
Yh changed it all was running ok then the eml come up with the code saying p000a slow response now its noisy every time I start it like there is not enough oil gettin up but I didn't have that problem before so don't know why it's like it now :/ @dazza
Offline ginge 0116
    • The kings cross hotel blackpool
« Reply #5 on: November 22, 2014, 01:07:49 am »
I had the same issue with mine only solution was to change the adjuster it's self. Not cheap though over 300 quid just for the part then labour. Very quite now and no errors! Hope this helps.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: November 22, 2014, 09:52:11 am »
@Carl123 did you buy a new cam adjustor sensor?
Offline Carl123
« Reply #7 on: November 22, 2014, 07:26:30 pm »
@ginge 0116 Yh I just find it weird because it didn't have the problem before the chain was replaced...it also gets quieter the longer it's driven :/
@dazza Yh sensor was changed also very irritating now!!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #8 on: November 22, 2014, 08:55:51 pm »
If the sensor wan not new i would say it could be faulty. Cant you bodge a connection on your old one to test it.
Offline Carl123
« Reply #9 on: November 22, 2014, 10:20:13 pm »
Might have to try anything I've still got the old one aswell worth a try I suppose @dazza
Offline Carl123
« Reply #10 on: November 22, 2014, 10:21:40 pm »
Also googled about this problem some ppl say do a oil and filter change and it sorts the problem but I'm not totally convinced!!
Offline doylebros
« Reply #11 on: November 22, 2014, 10:30:10 pm »
I would look at the sump oil strainer pick up pipe as a possible for oil starvation rather than the oil and oil filter.
http://www.mk5golfgti.co.uk/forum/index.php/topic,68442.0.html
