Author Topic: just got some new alloys  (Read 2447 times)
Offline red-snake
  • RED-SNAKE
« on: November 16, 2009, 12:58:06 pm »
iv just got some new alloys and the offset is 37 when is should be 42 will this cause me problems please help
Offline CarrG
Re: just got some new alloys
« Reply #1 on: November 16, 2009, 01:38:56 pm »
They will stick out a little more. What width, 7.5/8"?
K1 Revo 2+
Ibis RS3
Offline red-snake
  • RED-SNAKE
« Reply #2 on: November 16, 2009, 02:00:17 pm »
SAYS 8J WILL THESE BE OK AND THANKS MATE FOR THE INFO
« Reply #3 on: November 16, 2009, 03:53:23 pm »
....Using CAPITALS throughout is seen as SHOUTING - If I don't inform you of this, I'm sure that others or a Moderator will.
Offline red-snake
  • RED-SNAKE
« Reply #4 on: November 16, 2009, 04:23:58 pm »
thanks mate i no for next time
« Reply #5 on: November 16, 2009, 04:49:36 pm »
Standard offset is 51 with a 7.5J wide alloy.
a 37 offset at 8J will stick out just over 20mm more than stock.
Is your car lowered?  If not you may JUST get away with it. If you are lowered then I would almost definitely say you will rub....quite badly!!
Offline red-snake
  • RED-SNAKE
« Reply #6 on: November 16, 2009, 05:29:38 pm »
no its not lowerd mate thats a big help
thanks to every 1
Offline Garth
    • My Build thread
« Reply #7 on: November 16, 2009, 05:49:24 pm »
Bear in mind that I have 8 x 18" alloys with ET42 on standard suspension and they rub on the front over big bumps (the screw in the arch liner) so I imagine any lower offset will rub badly over bumps even on standard suspension. It looks like there's very little clearance at the back on mine too but haven't had it rub yet. I fear once it's lowered, mine will rub there too :(
Offline red-snake
  • RED-SNAKE
« Reply #8 on: November 16, 2009, 05:58:51 pm »
i should of checked 1st iv just won them on ebay. should be picking them up 2moz so ill find out then.How much you lowering urs by
« Reply #9 on: November 16, 2009, 07:17:52 pm »
As everyone is saying: The further away from oem the ET value is, the more you have to consider how lowered the car is if you want to avoid rubbing. Another factor is how stiff the suspension is and so how much it needs to travel.
There's a cool expression but I think it applies more to show cars : -
Doing everything to avoid damaging your tyres is a no-brainer imo.
Offline TomB
« Reply #10 on: November 16, 2009, 10:31:08 pm »
You're more than likely going to need some longer bolts too, as I doubt the old ones will work!
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
