Author Topic: Crap first start  (Read 4461 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=f17q30tqvb8l5gr1395u2ffrf4&/topic,19740.0.html
Crap first start
« on: December 11, 2014, 11:40:55 am »
So.... battery brand new, so its not the battery.
The first start of the day is usually crap.... sounds bad, and seems to only just kick into life....
Once started the car runs fine
Any clues?
Rich
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Crap first start
« Reply #1 on: December 11, 2014, 11:45:09 am »
Mine will do that if you let go off the starter as soon as the first 'fire'
If you hold the key until its 100% started then it's fine.
My battery is old which won't help, but as long as i hold the starter on until it's 100% started/as soon as it idles nicely - then its fine
dansmith180
« Reply #2 on: December 11, 2014, 11:52:00 am »
Apparently its not uncommon for the TFSI's to stumble into life a bit, I read some bits on a TT forum saying their starts were a bit unconvincing sometimes.
If it's a cold morning or the cars been still for a while I sometimes turn on the ignition for 5 seconds (let the pump prime) then turn it off (keep the key in) then turn it back on, wait 5 seconds and start the engine. Or at least just wait 5 seconds after turning the ignition on once and that seems to help.
Offline ed30sam123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88570.0.html
« Reply #3 on: December 11, 2014, 01:05:26 pm »
Mine will struggle a bit on a cold morning but I don't worry about it, the fuel pump on this engine primes when the drivers door is opened I think.
Tornado red ED30 No. 0728
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
« Reply #4 on: December 11, 2014, 01:07:43 pm »
leon does the same too, so I changed battery and coilpacks and plugs,
app its a tfsi thing, even says it in the manual too
Tornado red ed30 #0728
Offline Hevoshullu
« Reply #5 on: December 11, 2014, 01:37:31 pm »
Mine fires up one cylinder at a time as well. It's not a pretty sight but it at least it starts every time and runs smoothly once it's running. I've also heard all the 2.0 TFSI motors of this era start like this when cold.
Offline cuprajake
« Reply #6 on: December 11, 2014, 02:33:37 pm »
there basically a tractor lol
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #7 on: December 11, 2014, 02:52:17 pm »
My neighbour slags me for having a diesel because of the start up noise on my GTI!
Offline weyland
« Reply #8 on: December 11, 2014, 04:42:01 pm »
Glad Im not the only one, when I start up my GTI for the first few seconds it does sound a bit like a diesel  :ashamed:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: December 11, 2014, 04:57:08 pm »
My first start was crap. Used a can of BG44k in the fuel tank and it's been great for 3 months  :happy2:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #10 on: December 11, 2014, 06:03:26 pm »
Haven't seen this stuff before... Similar to redex?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #11 on: December 11, 2014, 07:02:35 pm »
It's Redex that actually works
It gets great reviews on the internet, I gave it a go before my first & second oil changes and now the car jumps into life from a cold start whereas before it stumbled, missed, and eventually croaked into life.
The cause of the poor starting is a case of the TFSI dirty injector syndrome :sick:
Saintsteve
« Reply #12 on: December 11, 2014, 08:01:46 pm »
Injectors.Thats your problem.
Offline cuprajake
« Reply #13 on: December 11, 2014, 08:05:52 pm »
I've run some forte injector cleaner through the tank today, will see if it helps.
« Reply #14 on: December 11, 2014, 11:27:50 pm »
Wouldn't injector problem lead to general bad running too? Mine runs sweet once it's up and running (touch wood)
