Well ended up wrapping the dv pipe in the left over exhaust wrap as had no other use for it lol
Finally finished the hub swap.... a long story which i wont go into but its done,ill fit new track rod ends before wheel alignment then the whole lot has been new and will last for years to come:wink:
original steel hubs off and weighed are 8.8kg's so i saved 1.7kg's per side,nothing major but with the brake upgrade weight savings a total saving of 8.2 kgs per side on the front and savings on the walk kit and superpro arms it was well worth it
ill weigh the arms and walk for future reference later
cheers
