Author Topic: BSH PCV Stage 1 vs Stage 2...  (Read 4780 times)
Offline t20lau
    • Website design Sheffield
« on: November 20, 2009, 09:08:04 am »
I know the difference is in the Catch Can...
But is the Stage 2 much more of an advantage?! I'm just not too confident I'll remember to keep emptying my Can, so thinking about selling the Stage 2 and buying a Stage 1!!!
SEAT Ibiza Sport | Vauxhall Astra VXR | BMW Z4 M-Sport | VW Golf GTi Edition 30 | BMW F30 330D X-Drive
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
Re: BSH PCV Stage 1 vs Stage 2...
« Reply #1 on: November 20, 2009, 09:17:59 am »
IIRC it was advised to just empty can everytime you change the oil ;) so i think you would remember ?
i would stick with the stage 2 mate, seems a lot more practical
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline t20lau
« Reply #2 on: November 20, 2009, 09:21:22 am »
From what I'm reading the Can will fill up quicker the more you are in higher revs (Not that I'll be sitting at 6500rpm), but this does mean the can could fill up and I'll not know or remember...
I'm just wondering Stage 1 vs Stage 2, is there an actual advantage?! I mean does the Stage 2 help the engine even more than the Stage 1 or isnt there much of a difference?!
Thanks,
Tom
Offline bacillus
  • -Receive: 451
« Reply #3 on: November 20, 2009, 09:29:06 am »
stage 1 = fit and forget but your intake valves will be subject to depositation of crud from the oil vapours to the same extent as having the oem pcv.
stage 2 = more protection from deposits on your intake valves but you need to empty the can ever so often dependoing on your driving style, time of year ang what oil you're using.
« Last Edit: November 20, 2009, 09:43:47 am by bacillus »
Offline t20lau
« Reply #4 on: November 20, 2009, 09:40:17 am »
stage 1 = fit and forget but your intake valves will be subject to depositation of cdud from the oil vapours to the same extent as having the oem pcv.
icic...
Yeah I'm just not too keen on the emptying part LOL!
So I'm guessing that Stage 1 have advantages over Stock...and Stage 2 has advantages over Stage 1, but Stage 1 has the advantage over Stage 2 when it comes to being able to "fit and forget"?!
Offline bacillus
  • -Receive: 451
« Reply #5 on: November 20, 2009, 09:45:43 am »
Yes stage 1 will put to an end any loss of boost from a leaking oem pcv.
Offline t20lau
« Reply #6 on: November 20, 2009, 09:51:19 am »
Thanks matey!
Think the Stage 1 is probably more suited to me really! I want to see the advantages, but not have to remember to empty the can, or more so, have the fear of it filling up before I've emptied it (end of the day is a guessing game right?)
Offline Bogwoppit
« Reply #7 on: November 20, 2009, 11:22:06 am »
If you get the high capacity catch can then it has a dipstick so you can check the level.
« Last Edit: November 20, 2009, 11:47:14 am by Bogwoppit »
Offline t20lau
« Reply #8 on: November 20, 2009, 11:24:54 am »
For some reason I read your message as is read..."If you get the high capacity catch can then you dipstick"  :signLOL:
Yeah I guess so...
« Reply #9 on: November 20, 2009, 11:31:16 am »
If you modify your car in any way this will increase the regular maintenance you should carry out. I for one have no issue with this but if you do you should think carefully before modding.  :happy2:
It's a two minute job to empty the can and at most you will need to do this every few months.  :smiley:
Offline t20lau
« Reply #10 on: November 20, 2009, 11:35:37 am »
Point taken...
I'll see how it goes! Not 100% sure still!
There are Pro's and Con's to both IMO, and for my personal use!
Offline BMX
« Reply #11 on: November 20, 2009, 12:21:28 pm »
i have fitted the latest oem pcv and it is holding the remap boost presure perfectly its the revision L the one i removed was F
"If Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
Offline bacillus
  • -Receive: 451
« Reply #12 on: November 20, 2009, 01:16:14 pm »
fwiw if you install the stage 1 fix, you can upgrade at a later date to stage 2 with catch can without having to purchase the full stage 2 dedicated kit. This upgrade kit is cheaper than the dedicated stage 2 kit.
  • -Given: 380
  • -Receive: 442
« Reply #13 on: November 20, 2009, 05:33:58 pm »
@ Bogwoppit:
In your Reply #7 you've posted a pic which very clearly shows a nice adjustable fixing ring. Did it come from BSH or elsewhere?
Thanks  :happy2:
Offline QD MBE
  • -Receive: 102
« Reply #14 on: November 20, 2009, 05:45:20 pm »
@ Bogwoppit:
Thanks  :happy2:
Mr Red,
I have that can, and the retaining ring in the pic, is supplied by BSH.
