Author Topic: Wheel fitment audi ttrs rotors  (Read 3936 times)
Offline ruhaleali
« on: January 06, 2015, 09:13:41 pm »
Hi, I am looking to fit TT RS Rotors on my gti fitment 5x112 and offset of 45. Will these wheels fit straight on without having to roll arches etc as I have normal ride height.
Kind Regards
Offline Shoy1980
Re: Wheel fitment audi ttrs rotors
« Reply #1 on: January 06, 2015, 10:07:33 pm »
How wide are they?
Offline xjay1337
  • -Receive: 377
« Reply #2 on: January 06, 2015, 10:08:25 pm »
Nothing to do with width or offset, is to do with clearance
you can have two wheels 18x8 et40 one will EASILY clear TTRS brakes where as another will barely clear stock 312
best to check first if you are unsure by test fitting that's the only way to be sure.
dansmith180
« Reply #3 on: January 06, 2015, 11:23:29 pm »
What wheels exactly are they? Because as @xjay1337 said it's more about the design of wheel than just offset/ width
As an example my current wheels are 8j et45 and only just clear but I bought some 18" BBS CH reps as winters which were 8j et42 and the wern't even close to fitting, I would have needed a 12mm spacer minimum.
Offline samiul11
« Reply #4 on: January 06, 2015, 11:28:53 pm »
I think these are the wheels  :innocent:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #5 on: January 06, 2015, 11:41:55 pm »
I have the 19" 8.5j version on mine and they fit over the r32 calipers nicely.
Tiny bit of scrubbing if I go over bumps with passengers but not too bad.
Jas
VCDS (Preston, Lancashire)
Online Andy
« Reply #6 on: January 06, 2015, 11:47:26 pm »
Am waiting for  @rich83   to be up my part of the country so can try my alloy on his car to check for clearance  on his brakes  :innocent:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #7 on: January 07, 2015, 07:23:24 am »
Hes not specifically asking about clearing brakes i dont think....
I had 18x8 ET45 CHs are they were fine
« Last Edit: January 07, 2015, 07:30:34 am by JoeDarKa »
dansmith180
« Reply #8 on: January 07, 2015, 10:32:54 am »
Hahaha I've just realised what happened there, the wheels are called rotors and i thought he meant brake discs  :rolleye:
Assuming they're either 8.5j or less then they'll fit fine  :happy2:
Offline ruhaleali
« Reply #9 on: January 07, 2015, 11:01:59 am »
Haha sorry lads! Sticking to stock brakes need me a set of fat ladies to go on the shoes! 19s should do nicely!
Offline andyR43
« Reply #10 on: January 07, 2015, 11:07:07 am »
I have 19" on mine and they fit fine with just a small amount of very occasional rubbing on the arches as my car is lowered.  :happy2:
Keeping it original..............or not!!
Offline xjay1337
  • -Receive: 377
« Reply #11 on: January 07, 2015, 02:45:52 pm »
Ha ha ha haah
I just realised that as well
If they are 18x8.5 et45 you'll need 205/40 or 215/35 tyres or you will look ridiculous and rub.
