Author Topic: Bluetooth module advice  (Read 4493 times)
Offline SI-R32
  • -Receive: 126
Re: Bluetooth module advice
« Reply #15 on: January 15, 2015, 10:15:52 pm »
I couldn't agree more about everything OEM but sometimes the only answer for getting the latest VW tech to work is an after market device, but your choice of course.
I changed my clocks to the white ones so I could get newer Bluetooth working,  so I know what you mean
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #16 on: January 15, 2015, 10:31:16 pm »
Si that was me who posted about 3g not working. Thats why I bought a 7p6 unit now so mrs can still use my phone for whatsapp and netflix on the go.
Offline Cossie Killer
« Reply #17 on: January 15, 2015, 10:46:04 pm »
Why cant i find a 1K0 035 730D Bluetooth module??
Ps this is getting expensive.... I was expecting to pay between £50ish for the module so may rethink this as go with a parrot or an alternative.
« Last Edit: January 15, 2015, 10:48:04 pm by Cossie Killer »
« Reply #18 on: January 15, 2015, 11:19:34 pm »
Will the 5N0 work with an iphone5/6 and will it show caller id on my highline clocks? If so, i'll give one a go I think..... Not bothered about texts although phonebook would be good (not a must though).
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #19 on: January 16, 2015, 07:18:42 am »
Ill find out if it works with iphones. If it does you can have my 5n0 for 45 delivered.  It will show names of people calling on Highline display and phonebook
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #20 on: January 16, 2015, 08:59:59 am »
just had a look and it seems iPhones dont support rSAP and the 5n0 only supports rSAP. Unless you jailbreak your phone and use an rsap app or get a 5n0 ending in D, but then to get that one to work in highline you would need the £100 module from carsystems.pl
« Reply #21 on: January 16, 2015, 02:17:13 pm »
So is there a way of getting this to work with my current Iphone5 for less than £150.00?
I note on the ross-tech site and these seem to tick all the buttons, I assume they cant be used as they dont have the HFP accessibility ?
Control Module   Type   PR-Code   Protocol   3G   HFP   PBAP   A2DP   rSAP   SOP
3C0-035-730   UHV-Premium   9ZW   DDP   No   No    ???    ???   Yes    ???
3C0-035-730-A   UHV-Premium   9ZW   DDP   No   No    ???    ???   Yes    ???
3C0-035-730-B   UHV-Premium   9ZW   DDP   No   No    ???    ???   Yes    ???
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #22 on: January 16, 2015, 02:21:29 pm »
If theres no HFP then it will use RSAP. same situation as using a 5n0 again.
You can use 7p6 kit and the 100quid module to use highline menu then youre looking around 230 - 250 ish for everything. Cheaper to get a 2nd hand fiscon
Not sure about any other modules tbh
Offline andyp
« Reply #23 on: January 16, 2015, 03:45:09 pm »
So having an extra module is needed to get everything working on a highline red dash?  Would it make a difference if you have an mfsw or not?
Good information on what will work with an iphone when trying to look for a module
« Reply #24 on: January 16, 2015, 08:07:47 pm »
Right, im going to have a punt on a 1K8-035-730-D seems to show DDP, No rSap, and HFP...... Can be bought from fleabay for around £100 delivered.
