April 23, 2025, 01:18:52 pm
All Things Mk5
Mk5 General Area
MFSW and highline clocks fitting.
Pages:
3
Topic: MFSW and highline clocks fitting. (Read 7206 times)
olsen-72
Always Involved
-Given: 24
-Receive: 21
Redditch
Re: MFSW and highline clocks fitting.
Reply #30 on:
February 07, 2015, 05:51:54 pm »
Steering wheel controller must be coded. Its not just plug and play. Than Basic settings etc.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL - SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
andybon
Won't Shut up.
-Given: 11
-Receive: 8
Reply #31 on:
February 28, 2015, 04:45:00 pm »
Just out of intrest if I am to go back to my old clocks (when I come to sell the car) can I just refit my standard clocks and steering control module over without coding, or will they need to be recoded in to the car again?
Also the mute button doesn't work on my wheel, is there a fault somewhere?
How hard can it be?
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Reply #32 on:
February 28, 2015, 05:09:21 pm »
just plug them both back in, but your mfsw may not work if you change your controller back to standard.
#RetroRaz -
https://instagram.com/retroraz/
andybon
Won't Shut up.
-Given: 11
-Receive: 8
Reply #33 on:
February 28, 2015, 05:11:26 pm »
That's good to know.
It's just for when I sell the car, I will be stripping it back to as standard as I can, still not done the clocks yet as the lad who was doing it, his version of vag commander wasn't working so we couldn't do the clock swap.
How hard can it be?
RetroRaz
-Given: 32
-Receive: 194
Reply #34 on:
February 28, 2015, 06:19:21 pm »
when u do change it back to standard, you may need to reset some of the errors with vcds as you would have removed the steering wheel.
#RetroRaz -
andybon
Won't Shut up.
-Given: 11
-Receive: 8
Reply #35 on:
February 28, 2015, 06:53:25 pm »
That's not too bad, I know when I swapped the wheel over last time I didn't get any warning lights that appeared so I'm hoping it shouldn't be a problem.
How hard can it be?
Pages:
3
All Things Mk5
Mk5 General Area
