Author Topic: Wheel spacers  (Read 2336 times)
Offline Stig_gti
Wheel spacers
« on: February 25, 2015, 08:57:42 am »
Morning guys.
I have a mk5 gti and will be fitting ttrs brakes with 340 tts discs.
Which size spacers will I need to fit under pro race 1.2 alloys thanks.
dansmith180
Re: Wheel spacers
« Reply #1 on: February 25, 2015, 09:26:54 am »
What offset and width are they?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=3fg9r9cco6siq30euvo65erbel&/topic,19740.0.html
Re: Wheel spacers
« Reply #2 on: February 25, 2015, 09:32:31 am »
You might get away without any
Offline xjay1337
  • -Receive: 377
Re: Wheel spacers
« Reply #3 on: February 25, 2015, 09:59:04 am »
If you can hold on a week tops I will tell you.
I have the same wheels (18x8 et45) and the same brake setup.
I'm putting 12mm spacers on but that's more for looks than clearance.
I will report back after the weekend if you don't mind waiting.
Offline Stig_gti
Re: Wheel spacers
« Reply #4 on: February 25, 2015, 09:59:27 am »
They are 8" offset 45 tyres are 225 40 18.
Offline Stig_gti
Re: Wheel spacers
« Reply #5 on: February 25, 2015, 10:00:58 am »
Brilliant yes I can wait in no rush to get the brakes fitted.
Thank you
Offline mvb12
  • -Receive: 64
TTRS Calipers behind TD 1.2s
« Reply #6 on: February 25, 2015, 03:21:16 pm »
anyone running these behind TDs and not using spacers?
if your not using spacers what is the ET of the wheel
 :popcornsoda:
Re: Wheel spacers
« Reply #7 on: February 25, 2015, 03:23:01 pm »
@mvb12
Merged the topics...  :happy2:
Offline mvb12
  • -Receive: 64
Re: Wheel spacers
« Reply #8 on: February 25, 2015, 05:11:16 pm »
@mvb12
Tbh I would have thought someone would be running this set up already.  :ashamed:
« Last Edit: February 25, 2015, 05:49:55 pm by mvb12 »
Offline Stig_gti
Re: Wheel spacers
« Reply #9 on: February 25, 2015, 07:22:02 pm »
Anyone else no what size spacers would be required :happy2:
Offline mvb12
  • -Receive: 64
Re: Wheel spacers
« Reply #10 on: March 01, 2015, 10:31:51 am »
Info needed BUMP  :laugh:
dansmith180
Re: Wheel spacers
« Reply #11 on: March 01, 2015, 04:18:06 pm »
I'd be surprised if you needed more than a 5mm spacer. My wheel is 8j et45 (doesn't look as clearancy as the TD's) and they fit without a spacer JUST.
Offline xjay1337
  • -Receive: 377
Re: Wheel spacers
« Reply #12 on: March 02, 2015, 11:29:27 am »
Patience young padawan.
I'm just checking with Nick that I can use the unit tomorrow to sort my wheels out and I will be able to give you an answer then mate.
Offline GTI44
Re: Wheel spacers
« Reply #13 on: March 02, 2015, 10:23:08 pm »
You need a 3mm spacer, Alex at AKS can supply these and slightly longer bolts
Offline mvb12
  • -Receive: 64
Re: Wheel spacers
« Reply #14 on: March 04, 2015, 07:16:12 pm »
what et you referring too?
my mate running these with et35 and no issue although I wouldn't want such et on mine  :ashamed:
